Old 09-14-2013, 07:28 AM
Default Comp Cams
Is anybody running this camshaft in their LS?
Kevin
http://www.compperformancegroupstore...Category_Code=
Old 09-14-2013, 07:39 AM
Sieg's Avatar
Sieg Sieg is offline
Here's the cam card: http://www.compcams.com/Company/CC/c...csid=1411&sb=0
I like that 2000-7000 rpm range.
Old 09-14-2013, 08:45 AM
Is this camshaft pretty streetable? I am not up on cam specs.
Old 09-14-2013, 10:42 AM
Sieg's Avatar
I don't have any LS experience and little cam experience......hopefully someone with first hand info will chime in.
They're all streetable it really depends on the individual's driving style, trans, gearing, and typical vehicle usage IMO.
The wide rpm range tells me it should work well on the street.......and rev! But I'd really like to see a dyno chart to see what the torque and hp curves look like to better understand the cams drivability.
Old 09-14-2013, 11:18 AM
2000-7000 rpm range?
Nice work by the marketing department.
Old 09-14-2013, 11:39 AM
Are you saying that range is pretty much BS?
Old 09-14-2013, 11:41 AM
Those ranges are an arbitrary measurement anyway so I wouldn't worry too much about it.
Old 09-14-2013, 11:51 AM
Twoblackmarks...'s Avatar
Twoblackmarks... Twoblackmarks... is offline
Maybe I should not answer since I have no experience With LS, but anything over [email protected] I would think would be not very streetable (low end torque), but it really Depends on the rest of the engine, trans and rear end.
But People are different and may think something else than me, I looked over comps LS line of cams, and all seem to have much more Exhaust duration?
I think this cam would not be pulling very much before maybe 3000RPM, especially in an under 400cid motor.
But maybe the LS motors can get away With much more cam because of the good flow and long intakes and such.
This one I would say is maximum for street use in a good engine but still "fun", but I just used 5 minutes "researching" this...
http://www.compcams.com/Company/CC/c...csid=1402&sb=0
On a non-race car it is Nice to have the Power whenever you want it, just stomp on the pedal and there it is, dont have to wait for it
Old 09-14-2013, 01:28 PM
Sieg's Avatar
Like I mentioned..............dyno charts.
My Edelbrock 5002 grind is 2,500-6,500.........marketing is accurate IMO........but that's from marketing 25 years ago.
Old 09-14-2013, 01:37 PM
Pretty much! On an LS1/6 this cam will be dead down low ie under 3000 rpms and there are other factors involved that affect power band other than the cam. IMO, there's way too much overlap for a street car with this cam. However, everyone has mentioned how subjective streetable is and that's very true. You have to look at the total drive train and you're driving style. So what's the rest of the drive train look like on your car? What do you want power wise? I'm not referring to just the amount of power but where you want your power. What other engine mods, if any, do you have currently?
An example of a cam that I really like for all around street performance on an LS1/6, is a 228/232 on either a 112 or 114 depending on auto or manual trans. This was ground on Comp's XER lobe grind but they have changed their grind names so I'm not sure what new name corresponds. To me, this cam worked great on a stock LS1/6 with simply headers, exhaust, and normal gearing(ie mid to low 3.0s) but also would only get better with more mods like heads and intake. It was a simple off the shelf grind that works well for a street car. Nothing fancy or exotic. It just worked.
