Old 10-06-2013, 12:30 AM
67goatman455 67goatman455 is offline
Default rear solid axle scrub radius?
I'm not even sure if this even a......THING? I couldn't find an answer to this in any of Ron's threads (unless i missed it)
i think the title asks the question enough already but is there a good formula to figure out what is needed for the rear coil-over shock angle? I read on here a while back its basically the same as the front, you want to get the scrub radius in the rear as close to "0" as you can?
This picture shows the ridetech coilover kit installed on my car. I instantly started wondering why there is even a lower relocation bracket, as i have room to mount it in its original location, which is located about an 1-2" inside the wheel or so.
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 10-06-2013, 04:48 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Scott, the scrub radius term does not apply to a solid rear axle. Also, it does not have anything to do with the shock or shock angle in the front.
It is where a line is drawn thru the upper and lower ball joints, that intersects the ground plane. The scrub radius is the distance from the center of the tire contact where it meets the above intersect line. So unless you have "rear axle steering" you wouldn't have a rear scrub radius.
Not sure if there is an ideal rear shock angle, but the factory put them out a bit too far (~25+ degrees). Originally our cars all had a lot more body roll therefore the higher angle made more sense as it is more perpendicular to the body roll angle. The more vertical it is, the more 1:1 it is with axle travel. Drag racers usually run them straight up of course.
I'm sure Ron will come across this and elaborate. He is very helpful.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
