Old 11-11-2013, 02:54 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default a/c mount options for C5 accessories
I'm doing a turbo setup on my Chevelle and looking for an a/c mount that hugs the engine the closest in the passenger side valvecover location. I have C5 Vette accessories on the car.
What options are there?
This one seems to stick out really far? Is this really my only option?
Old 11-11-2013, 07:06 PM
130fe 130fe is offline
Post
I used the Holley bracket with my corvette brackets. I like it a lot. For the price, you can't beat it. I know Vintage Air sells a bracket that mounts it low pass side area but space might be an issue. Hope this helps you.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 11-13-2013, 09:36 AM
jovozx12's Avatar
jovozx12 jovozx12 is offline
I think the kwik bracket and the holley bracket are about the same placement. The holley brackets look more oem and matches the corvette accessories.
Old 11-13-2013, 10:48 AM
Musclerodz's Avatar
I have had nothing but issues with kwik brackets. I have run the holley brackets and they work flawlessly.
Mike Redpath
Musclerodz & Customz
facebook page
Old 11-13-2013, 03:24 PM
gnx7's Avatar
Holley bracket it is!
Old 11-13-2013, 04:28 PM
samckitt's Avatar
samckitt samckitt is offline
I have the Holley bracket with the Vette alt/PS bracket. I have the bracket for the sanden compressor, not the R4 one. It fits good & looks stock, haven't ran it yet so I cannot comment on that side.
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-14-2013, 04:49 AM
rickpaw rickpaw is offline
If you want an AC bracket that hugs the block, Holley bracket sticks out the same amount as the Kwik bracket that you have, so not much to gain by switching out to Holley bracket. Almost all of the brackets that tugs the compressor to the block are the billet kind (VA front runner for example).
Tu Ho
Old 11-14-2013, 06:24 AM
Bsinclair Bsinclair is offline
you will have to purchase a front drive system like vintage air or wegner to get it tucked in like you are wanting..
this is a wegner system on my car and you can see how compact it is. yes they are expensive but well designed. something like this may help package your turbo setup easier though...
Old 11-14-2013, 08:28 AM
After all the failed fitments and alternators hitting the inner fenderwells, power steering hose hitting pitman arms we stepped up to the Wegner kits too. The fit super close and tight. Plus they give you everything with the kit. Water pump, power steering pump, alternator and harmonic balancer. We put them on all of our LS builds.
Im sure GNX7 might have all the parts so a holley bracket should be fine. But its gonna take some magic to get turbo tubing past that.
Old 11-16-2013, 07:09 AM
gnx7's Avatar
What style harmonic balancer does the Wegner kit use? Ie Fbody/truck/vette/GTO
My fabricator has the skills.... We are also trying to package a massive Chiseled Perf a/w intercooler in there also. Space is getting tight
