Old 12-01-2013, 01:10 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
Default LS Parts, BMW Seats ""Reduced Prices""
Item Location (City/State): Las Vegas, NV
Price: $1234
Description: Used Parts
Cleaning out the garage and have many LS parts for sale. Located in Las Vegas, NV
LS1 motor out of a 2000 corvette. It appears to be low mileage. Comes just as pictured with intake (not an LS6). Has a DBW throttle body. No injectors or fuel rails. Heads are 853s $1600 Sold
LS3/L92/L99 823 casting Heads. These are off a 2011 camaro with 13k on them and come with stock valves and valve springs. These are not the sodium filled valves. $600 Sold
LS3 821 Casting Heads. These are bare castings, no valves or springs included. Came off of a 2010 Corvette with 30k on it. $325 Sold
LS1 853 Casting Heads. Come with stock valves and valve springs. $100
LS Rocker Stands. Will fit all LS based engines except for the LS3/LS7 type heads. $25 for the pair.
L92 Truck intake. Requires rectangle port heads and a 4 bolt Throttle body. No fuel injectors or rails included. $50 Sold
LS1 5.7L Pistons and rods. I only have 7 pistons and 7 rods. $75
LS1 F-Body water pump. $50 Sold
LS1 F-Body Balancer. $40
LS1/LS6/LS2 Valve covers with bolts. $50
LS2 Oil Pump. This should fit any LS style motor. I pulled this out of an LS2 that was in a CTSV with 73k on it. $30
PCM 896 Red/Blue $50 Sold
LS Pushrods Stock Length 7.4 These are stock. I have 2 sets. $20 per set.
LS Chromoly Pushrods 7.550 .080 by Texas Speed $80
LS1 Valley Cover. $30
LS1 Front Cover. $30 Sold
LS1 Rear Cover. $30
Cloyes timing set. this a double roller set for a gen III motor with a 3 bolt cam. It is brand new however the machine shop lost the crank sprocket so all i have is the chain and the cam sprocket. Part #9-3159 $30
LS1/2/6 16 Stock Rockers. The trunions have been removed and are ready for the comp trunion upgrade. $45
LS 3 bolt DBW throttle body with sensors. part # 25317951 $60 Sold
MAF stock 78mm 3 pin plug. $40
LS1 Steam tube. may have to be messaged a little back into shape. $25
Weiand Team G single plane Small Block intake. $60
C5/C6 Front and Rear Brake calipers and Abutment brackets. $400 Sold
BMW 3 series seats. All power and easy to hook up 2 wire install. $300
Jerry 712-253-7583
Jerry
Old 12-02-2013, 07:29 PM
jovozx12's Avatar
Parts list updated.
Jerry
Old 12-04-2013, 05:54 AM
jovozx12's Avatar
Price drop. Prices have been updated.
Jerry
Old 12-04-2013, 11:52 AM
CamaroMike's Avatar
CamaroMike CamaroMike is offline
Do those brakets allow the calipers to bolt up to 69 camaro spindles?
Old 12-04-2013, 12:22 PM
jovozx12's Avatar
They do if you have ATS spindles. If you don’t I believe you would have to buy the brackets from Kore3.http://www.kore3.com/proddetail.php?prod=10083-02
Jerry
Old 12-10-2013, 11:45 AM
jovozx12's Avatar
To the top
Jerry
Old 12-15-2013, 04:01 PM
jovozx12's Avatar
To The Top
Jerry
Old 12-18-2013, 08:51 PM
jovozx12's Avatar
LS1 is Sold!
Jerry
Old 12-19-2013, 07:27 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
PM sent about LS-3 heads
Old 12-29-2013, 10:57 AM
jovozx12's Avatar
All PMs replied to. Still have a lot of parts for sale.
Jerry
