Old 12-14-2013, 11:13 PM
64mali's Avatar
64mali 64mali is offline
Default what brakes should I go with?
So here's my dilemma. I want to upgrade my brakes and eventually have a hydraboost system with front and rear disk. Problem is $$$$ so I'm going to go in stages. The car (64 chevelle ) has gm disk brakes in the front and 12 bolt drums in the rear. I want to start with upgrading the front disk brakes. At the very least I was thinking new rotors with the D52 Wilwood calipers but of course I want to go at least 13" rotors. I guess my bottom line is are the D52 much of an upgrade? Has anyone used the 13" CPP disc brakes or the aftermarket C5 kits on Ebay? I want a good stopping and handling car. I might do some local auto cross events but I don't have the budget to build a full on track car, just a nice driver that I can play in from time to time.
Old 12-15-2013, 09:43 AM
makoshark makoshark is offline
The D52 isn't really much of an upgrade and so probably not really worth the expense of them.
Contact Kore3, they will fix you up. Sounds to me like a C5 brake kit would suit you well and Kore3 has all you need to make the swap.
http://www.kore3.com/
Old 12-15-2013, 10:01 AM
Sieg's Avatar
Sieg Sieg is offline
+1 > Call Tobin at Kore3.
Old 12-15-2013, 08:24 PM
64mali's Avatar
I just looked at the website and like what I see. If I understand it correctly it looks like all I need is the billet hub and big brake kit or do I need to get the AFX spindles? Have any of you guys run these brakes? What's the feedback?
Old 12-15-2013, 09:22 PM
you can go either way. C6 Calipers are the way to go budget wise. You can do the C6 rear with 13" rotors.
Old 12-16-2013, 12:44 AM
Sieg's Avatar
I'm running the C5 big brake kit up front w/ Wilwood 7/8" manual master and Hawk HP+ pads, and drums in the rear. With 245/40/18 Nitto NT-05's up front I have more brake than grip. Modulation is very good IMO.
Old 12-16-2013, 10:08 AM
130fe 130fe is offline
Sieg, what wheels are those VWW? what size backspace are you running, any spacers? Any info would be appreciated.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 12-16-2013, 11:06 AM
HELLCAMINO HELLCAMINO is offline
Can't beat a set of brakes from a 1998-2002 LS1 Camaro. Front and rear mounting brackets availible online. Grab some drum hubs and have em turned down to fit the rotor hat or buy a set of billets thru Kore3. Does the job for me on a budget. I got amy fronts on Craigslist for $200 and the rear set up off Ebay for $130. The drum hubs I got for free and you need disc spindles or if you have drum spindles they need milled down for rotor clearance. Most 17" rims will be fine, but 18's are the way to go for max clearance.
Old 12-16-2013, 05:06 PM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
X2 on Sieg's setup. I'm running the C6 in 340/330mm front/rear rotors with HP+ and a 7/8" Wilwood manual master as well. Phenomenal braking with excellent modulation. An adjustable prop valve is a must though.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 12-16-2013, 06:28 PM
aany001's Avatar
aany001 aany001 is offline
Call Tobin at Kore 3 he will set you straight!!!!!
