Old 01-29-2014, 10:49 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Power steering rack and pinion leak
Hello guys
I have got this power steering rack and pinion leak problems ever since I bought my car. The rack and pinion came with the Speedtech front clip kit that was installed by the previous owner and power steering leak issues started after driving the car for only 150 miles.
I have circled the areas where power steering fluid leak is taking place.
The high pressure hose as seen in the above photo is leaking as well plus the areas circled above. I cleaned the area circled in the 3rd photo, and I did not observe any leak afterwards
I am really surprised how power steering rack and pinion failed after 150 miles of driving.
Does this mean it is the time for a new power steering rack and pinion?
Your input guys will be appreciated
72 Camaro RS:SOLD
68 Camaro:
Old 01-29-2014, 11:30 AM
Blake Foster's Avatar
Is it a Unisteer Rack?
I would contact them directly to get their opinion ask for Marc Mercurio,
800-338-9080
Blake Foster
www.speedtechperformance.com
Old 01-29-2014, 11:42 AM
72Z/28's Avatar
800-338-9080
Hello Blake
I don't know if it is a Unisteer rack but this came with Speedtech front clip that was purchased by my friend. I sent you a PM long time ago regarding this issue.
72 Camaro RS:SOLD
68 Camaro:
Old 01-30-2014, 12:58 PM
72Z/28's Avatar
Am I the only one with power steering leak!!!!!
72 Camaro RS:SOLD
68 Camaro:
Old 01-30-2014, 05:52 PM
70 tt rustang's Avatar
70 tt rustang 70 tt rustang is offline
What style rack is it? I know with a mustang 2 you need to change the valveing on the pump to get it down to 2gal per min.
just a thought
Old 01-31-2014, 01:46 AM
72Z/28's Avatar
just a thought
Well I am not what style it is but it was bolted on to the Speedtech subframe kit when the kit was ordered from them.
As far as the power steering pump, I believe it is the one that comes with LS6 crate engine.
72 Camaro RS:SOLD
68 Camaro:
Old 01-31-2014, 10:08 AM
Well then it is a Unisteer Rack.
you do need the 2 GPM power steering pump.
if I missed the email you sent I apologize.
in a couple of the pictures it looks like the mounting bracket has been modified?? where the rack mounts to the bracket, not sure what is going on there.
The leak at the Banjo fitting is likely just that it needs to be tightened or was tightened incorrectly and has damaged the seal.
Make sure!!!! the pressure line is on the correct port!!! the pressure "IN" port is the one that is lowest on the pinion housing. If this is hooked up incorrectly and has been pressurized then the seals inside the unit will probably be blown. and this will cause the unit to leak.
sometimes the fluid coming from the housing separation is left over assembly fluid.
The fluid also appears to be RED is it ATF or Power Steering Fluid??? DON't use ATF!!!!
let me know if this helps you can call as well if you need to 435-628=4300
Blake Foster
Old 01-31-2014, 10:12 AM
The standard LS power steering pump would be a 3 GPM so the restrictor/ flow valve needs to be changed to a 2 GPM Billet Specialities sells them part # RP1300
this "normally" wont cause any issues if it has not been drive much but will make the steering way to light and will increase the heat build up in the fluid as it tries to bypass too much fluid. as well it may cause air in the system and it will be impossible to bleed out.
Blake Foster
Old 01-31-2014, 02:16 PM
72Z/28's Avatar
Hello Blake
Honestly you have been very supportive and answered all my queries whenever I send you or I had sent you PMs.
The leak at the hose fitting is the high pressure one that is coming from the pump. However, not quiet sure about the capacity of the pump itself. It is the one that came with crate engine.
Unfortunately I am using the ATF from AcDelco.
As per your feeback the pressure line is on the correct port
I am not sure if the mounting bracket was modified. I do appreciate if you send me a photo showing the correct way of mounting the bracket
I will try to get the one from Billet specialities.
72 Camaro RS:SOLD
68 Camaro:
Old 01-31-2014, 03:53 PM
GET THE ATF OUT!!!
if there is an issue with it leaking, and it goes back for warranty Unisteer will instantly void any warranty if it has ATF in the rack, it specifically says in the unisteer instructions "DO NOT USE ATF"
Blake Foster
