Old 06-29-2014, 11:31 AM
carbuff's Avatar
carbuff carbuff is offline
Default Remote shock canister mounting
Since several of you are, I believe, running the Ridetech triple-adjustable or similar shocks which have a remote canister, I'm curious as to where you are mounting those canisters on the rear of your vehicle? I'm considering a change to a set which will have a canister to mount, and I don't know where to put it. The seemingly obvious place is in the trunk, but unless I'm mistaken, that means drilling a couple of 3" or so holes to pass the canister through. There aren't any quikc-disconnect type fittings on those canister hoses, correct?
How have you guys dealt with this?
There just isn't a good place under my car for them, at least not one where I could get to it to change the settings without getting the car in the air. SO trunk mount would certainly make that part easier. And I have the rear downbars from my rollbar in the perfect spot for mounting them.
Suggestions? Thoughts?
Old 06-29-2014, 03:19 PM
Ron Sutton's Avatar
Hi Bryan,
I sent you an email outlining some options with quick disconnects. The steel ones are pretty affordable & I think that offers you a solution.
Ron Sutton Race Technology
Old 06-29-2014, 04:29 PM
Originally Posted by Ron Sutton View Post
Hi Bryan,
Ron, I'd be willing to bet plenty of members (myself included) would love to read what you have to say and recommend on the subject.
Old 06-29-2014, 07:03 PM
SSLance's Avatar
SSLance SSLance is offline
Too late for me, I already cut two 3" holes in my trunk floor. I'm still working on a solution to fill them back in in a way that will seal the hose off yet still leave a way to remove the shocks if necessary.
Lance
Old 06-29-2014, 07:50 PM
rchaskin's Avatar
rchaskin rchaskin is offline
Look at the build thread for the 1969 Goodguys Camaro.
They made some neat covers for the 3" holes in the trunk floor.
Randy
1971 Nova
https://www.youtube.com/user/rchaskin/videos
Old 06-30-2014, 06:00 AM
Yelcamino's Avatar
Yelcamino Yelcamino is offline
Maybe you could use one of these Lance...
http://www.sealsit.com/grommet_split.asp
Herb
1966 El Camino LS408/T56Magnum
1966 Chevelle 509/T56Magnum
1963 C10 454/4L80
PHR CHP CHP Youtube
Old 06-30-2014, 08:03 AM
SSLance's Avatar
I actually bought the 3" version of those and they didn't fit. The 3" measurement is outside to outside of the metal part of the seal. When put together they would just slide down completely through the holes in my floor.
Great product and great idea, we just need them in a 3.5" size is all.
Something to think about, the company states that they'll make custom sizes for larger orders. Maybe if enough of us got together on a group buy we could have them make a run of them that will fit a 3" diameter hole?
Lance
Old 06-30-2014, 09:54 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
I chose to no cut the big hole in the trunk. Not ideal from a looks standpoint, but easy to get to. Plus it's a full frame car, so you may not have a place to mount them like this.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 06-30-2014, 12:09 PM
Ron Sutton's Avatar
Okie Dokie ...
In road racing, we use shocks with quick disconnect hose canisters. They typically come with the shocks from the manufacturer. I "thought" the aftermarket quick disconnects (that hold pressure) we use for brake lines, hydraulic clutch lines, etc ... might work. Not. Because the Ridetech hoses uses an ORB fitting with special threads, the commonly available hose quick disconnects (with AN or NPT Threads) will not connect.
But Seals It DOES offer split 2-piece seals that are 4.5" OD to cover the 3" holes for the canister to go through, just as Herb mentioned above. I carry them HERE.
Reminder: To those that don't already know this ... do not disconnect the hoses off your shocks ... as pressure & oil will come out.
Old 07-01-2014, 08:01 PM
Buick Grand National Guy Buick Grand National Guy is offline
Default Mounting remote shock reservoirs...rear
I mounted mine to underside of my 84 Grand National frame behind wheel.
Copied location from Ridetech's Chevelle. FWIW, the adjusting screw is sealed against weather so rain, dust, etc coming off rear tires will not be a problem.
Conrad
Original owner of 1974 Z28. Ordered car with 4 speed, LT, Air Conditioning. Numbers matching car. Now equipped with Edelbrock Pro Flow fuel injection, 96 Zette Wheels, B-Car front disk, WS6 rear disk.
Also original owner of much-modified 1984 Grand National. Ridetech front & Detroit Speed rear control arms/sway bars Ridetech 3-way coil overs. Champion aluminum heads & intake. Comp roller hydraulic cam. CF hood, fiberglass bumpers. Baer 6P (2-piece rotors) 14" front & 13" rear brakes.
