Old 08-21-2014, 10:01 AM
captainofiron's Avatar
captainofiron captainofiron is offline
Default Rear suspension advice needed on a 68 Firebird
Its a 1968 Firebird, and Im going to use a 8.2 BOP rear axle.
I had planned on using CAT-5 Global West leafs.
The plan is to have a fast cruiser that might occasionally see some track time. But I want a car that can handle curves well as I have been known to blast down hilly/curvy backroads. I dont mind if the ride is a little harsh, but I dont want it to feel like I am going to lose a tooth filling driving around.
I was looking at some of the 4 link type retrofit kits, and I think they would be out of my budget, OR delay the car quite a while
Thoughts?
Old 08-21-2014, 10:19 AM
DBasher's Avatar
DBasher DBasher is offline
Nothing wrong with a good set of leafs and the right shocks. I have zero exsperiance with firebirds so can't recommend any companies, look over there
for vendors that offer what you need.
I'm running JRI and QA1 stuff on my junk...a buddy has ran both RideTech and QA1 on his charger and likes the RideTech shocks much better.
Dan
Old 08-21-2014, 10:47 AM
Rod P's Avatar
Rod P Rod P is offline
just looked that up and
Leaf vs Link
Cat 5 leafs are $816.00 bucks
those also require the Del-A-Lum Shackle Kit for $193.12 to make them function as intended (say so in the Globalwest directions)
Ridetech 4 link $1300 bucks
shock/coilover setup
shocks for leafs part #22189842 $350 pair
Coil over for link part #11166509 $550 pair
total
Leafs-shackles and shocks $1359.12
Link and coilover $1850
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-21-2014, 11:29 AM
Leaf vs Link
total
Awesome
I hadnt seen any Bolt on type kits, and that is pretty reasonable price.
How is the quality?
Old 08-21-2014, 01:46 PM
Rod P's Avatar
Originally Posted by captainofiron View Post
Awesome
I hadn't seen any Bolt on type kits, and that is pretty reasonable price.
How is the quality?
pretty good! I'm sure someone will back me up on that
Rod Prouty
Bangshift Stories
Old 08-21-2014, 03:14 PM
Haha, nice!
Yea you guys have convinced me. I didnt think I could get a 4 link set up for under $2500 let alone 2k
I was reading through the instructions, seems pretty simple install. Only thing that might kick my butt is the welding onto the pumpkin. My welding skills are lacking, but I do have a buddy that is pretty good. Either that or get a shop to do it.
Old 08-21-2014, 05:58 PM
Bad94 Bad94 is offline
I run the RideTech bolt in 4 link too, and very happy with it.
Above Average Motorsports
1972 Nova, Ride Tech, Forgelines, Wilwood, Bowler Transmission, Lingenfelter, RAFT.
Old 08-22-2014, 07:15 AM
Do you run a sway bar with that 4-link?
Also seems like with teh coil overs, it would be easier to put in mini-tubs
Old 08-26-2014, 05:24 PM
I have the Camaro rear bar on mine.
Old 08-26-2014, 06:27 PM
ma73z's Avatar
ma73z ma73z is offline
I just put the ridetech 4 link in a 69 firebird over the weekend and am super happy so far! If I didn't already have suspension for my 73 it would get it also.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
