Old 09-03-2014, 04:31 AM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by SlowProgress View Post
Mark when you get a chance please post up the thought process behind the Centerforce clutch over the LS9 clutch you were planning earlier.
Also, any photos of the liquid coolant loop routing would be appreciated.
Thanks for all the useful information!!
The LS9 clutch works great up to about 825 ft*lbs TQ. I was on the edge of capacity of that clutch in Red Devil and Mayhem. If you slipped (Got real hot) the LS9 clutch its high RPM reserve (Not fully releasing) was reduced. You would notice this on WOT 2-3s and 3-4s. The Centerforce will hold 1300 ft*lbs. Per Will Baty at Centerforce it will work fine with the F-body CSC but it will have better life with the GT500 Mustang CSC. It took a bit of digging but I found the GT500 part has less effective piston area so for the same master displacement it should stroke farther at the trade off a bit more pedal effort. I made my own Swedgelok quick disconnects and bench bled the system before I installed it. I'll try to take some pictures tonight. The pedal efforts seem correct to me about 35 lbs. On the high side for an OE application but good for a 957 HP Hot Rod. Statically testing it the pickup point seems correct so far I'm happy with it. Randy Johnson and Chris Smith let me drive there cars and the low speed drivabilty of the DYAD seems good. The true test come at the track.
Mark
Old 09-03-2014, 04:47 AM
Stielow's Avatar
We made a lot of progress over the weekend. My buddy Ryan Kuhlenbeck was back in town to help with the wiring. Intergrating the new Bosch ABS was not trivial. We finished the whole front engine bay harness. I have started on all the soft lines and I'm about half done. Jeesh this car has a lot of wires and hoses.
The rear axle and fuel tank are DONE!
Old 09-03-2014, 05:27 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Mark your work is always so impressive because when you open the hood it looks like it should have came this way from the factory,beautiful car
Old 09-03-2014, 06:05 AM
KPC67's Avatar
KPC67 KPC67 is offline
Kevin Carter
Old 09-03-2014, 06:11 AM
LS7 Z/28 LS7 Z/28 is offline
Who are you trying to fool with that wimpy LS9 engine cover.
Old 09-03-2014, 06:59 AM
Stielow's Avatar
She's all stock.... LOL
At most local car shows no one knows the differance.
Mark
Old 09-03-2014, 07:08 AM
Mark
Haha! throw some 302 badges on the hood for the hell of it. Keep 'em guessing.
Old 09-03-2014, 07:26 AM
Z06Joe Z06Joe is offline
This is such an awesome build!!!! Wanna sell it to me and start on a new one and do the things on that one that you didn't do on this one???
I know... I know...
Old 09-03-2014, 10:17 AM
looking good.
Don't forget to post pictures of Ryan's under dash work. Its always inspiring to see clean wiring.
Old 09-03-2014, 11:03 AM
OLDFLM's Avatar
OLDFLM OLDFLM is online now
Default Stielow Shop Cam
Where's the link for the "Stielow Shop Cam" so we can watch updates in real time? That's the only way to feed this "habit" imho!
Ty Ingle, USAF Retired
FREEDOMBIRD
