Old 11-25-2014, 01:33 PM
jlwdvm jlwdvm is offline
Default Rear axle catch can-breather ideas?
I had to remove the original breather that Strange installed on my new 9" because it was in the area that I had to weld on tabs for an upper arm. I will be drilling and tapping a new hole in the axle tube and need some ideal on what to use for the axle fitting, catch can, etc. I have cage tubing in the trunk area that the can could be mounted to and some lift over 6AN PTFE hose that I could use if needed. Any ideas?
Old 11-25-2014, 08:37 PM
Ron in SoCal's Avatar
AME makes a nice compact unit. The key is to mount it high so not much fluid fills the can. OTOH you could look at a Morso unit which holds more volume.
Ron in SoCal
69 Camaro in progress
Old 11-25-2014, 11:00 PM
Put the feed hose at the very bottom of the tank so the fluid will drain back down.
Old 11-26-2014, 07:56 AM
SlowProgress's Avatar
Default Two ideas
Nobody mentioned either one of these. They are costly but both built really well. Several designs available. The Finch version can vent two devices.
Old 11-26-2014, 08:40 AM
Do the II Much pieces just vent, or is there also some storage if lube makes it all the way up?
Old 11-26-2014, 06:01 PM
It's a vent only. From experience lol
Ron in SoCal
Old 11-26-2014, 07:51 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have the finch vent. Very good quality, and it works.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 11-30-2014, 07:04 AM
If you have IDIOTS (Steve's Auto Restoration in Portland Oregon) put your rear end in -- and they choose to install a vent on the gear side of the ring gear - it will throw lube up at the vent and no matter what you do it will push gear lube out the vent....
LOL
Finch makes great stuff -- but like most things it also depends on the installation.
Old 11-30-2014, 07:59 AM
mitch_04 mitch_04 is offline
^Kinda want to see a pic of that!
Old 12-01-2014, 12:40 PM
I will be removing my Strange 9" after mock up to finish welding on suspension tabs and get it painted. I am thinking about drilling a hole and welding in a bung on the upper front drivers side of the center section to run a line to a breather/catch can in the trunk. I think I read somewhere that this is where GMR recommends the vent.
