Old 12-13-2014, 11:19 AM
jdeliveryguy jdeliveryguy is offline
Love that nova. Quick question, what size wheel spacers are you using?
Also what subframe connector do you have on car. Thanks
Old 12-16-2014, 09:13 AM
70TWO NOVA's Avatar
70TWO NOVA 70TWO NOVA is offline
Thank you. I'll have to measure but I think they are 2" in the front and 3/4" in the rear. I have the Competition Enginerring bolt in subframe connectors.
Brian Miller
-1972 Nova
-1968 Camaro
-1967 C-10 step side 4x4
-2000 Dodge Dakota
it'll buff out........
Old 12-16-2014, 05:06 PM
70TWO NOVA's Avatar
Got the old carb Edelbrock Performer rpm off, here is a side by side with the new MPFI intake
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 12-16-2014, 09:05 PM
70TWO NOVA's Avatar
Just picked up some TPI fuel rails for it
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 12-16-2014, 09:29 PM
SSLance's Avatar
SSLance SSLance is offline
Looks like the new intake is for Vortec heads, and the old one wasn't. Are you going to adapt the Vortec manifold to the heads?
Can't wait to see how this works out for you. Which ECM and software are you going to run?
Lance
Old 12-16-2014, 09:32 PM
70TWO NOVA's Avatar
My heads actually have holes for both standard and vortec intakes. I will be running a micro squirt controller on it.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 01-02-2015, 07:53 PM
grendel grendel is offline
Still need a 4150 throttle body? I have one I never ran, somewhere. See attached... sat on my motor before I added the blower. Then of course, it didn't flow enough for the blower, so I had to go Dominator.
Uses all GM style IAC and TPS.
Heck, I hava RamJet 350 intake, throttle body and rails kicking around somewhere, too.
Nice build, I am contemplating a 69 with some cast off parts.
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 01-02-2015, 10:47 PM
70TWO NOVA's Avatar
Pm sent
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 05-12-2015, 10:23 PM
70TWO NOVA's Avatar
Got some parts, more on order. I should have everything sans the microsquirt controller soon. This weekend I'll have the fuel system done then on to some wiring.
Brian Miller
-1972 Nova
-1968 Camaro
-2000 Dodge Dakota
Old 05-13-2015, 08:04 AM
Good luck with it. Wiring to me is one of those things you just go into knowing it's going to take a long time to do correctly. I just sit down and just start working slow and steady.
