Old 01-21-2015, 11:18 AM
Justin@EntropyRad Justin@EntropyRad is offline
Originally Posted by kwhizz View Post
And here's the engine........It's only got 2100 miles on it
can i pee on this and claim it for my own??
Wicked setup overall
Old 01-22-2015, 03:40 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Hey Ken
Check your PM. Sent you an email too.
Completely wicked car man.
Jim
Old 01-22-2015, 04:30 PM
camcojb camcojb is online now
Ken,
Did they mention how much HP that setup would hold?
Old 01-22-2015, 08:04 PM
andrewb70's Avatar
Ken,
That driveshaft uses a custom billet CV that The Driveshaft Shop uses on their high HP drive axles. Since the drive axles see between 3 and 4 times (depending on R&P) the torque that the output shaft sees, durability is not a concern. The "fuse" in that link is the rear u-joint. The Driveshaft Shop also makes custom pinion flanges that will mount a CV. Here is one for a Ford 9", which is what I plan to use on my 1967 Cougar build.
Andrew
Old 01-22-2015, 08:22 PM
Thanks Andrew.
Old 01-22-2015, 08:25 PM
andrewb70's Avatar
Thanks Andrew.
Sure thing...I've been running one of those in my GTO since 2010. My front operating angle is about the same as Ken's.
Andrew
Old 04-18-2015, 06:17 PM
kwhizz's Avatar
kwhizz kwhizz is offline
Nice Sunny cool sunny day today and I got the Bug to get the Beater out and go to the Drag Strip...... Paid....went thru Tech....and pulled up to the line (Lot's of Prep)......LOL........When I got the Helmet out of the trunk I realized I still had all the normal travelling "Stuff" in the trunk.......Tool box, chairs, hydraulic Jack etc........LOL.......Made two passes......1st one just blew the tires off the car and had it sideways about a third of the way down the track..........2nd pass I drove it out and gradually got in it........2.3 60 ' time and went 12.21 @118..........Not bad for a Highway car........Easy 11's with Drag Radials.......But.......once is enough.........LOL
Old 04-18-2015, 06:22 PM
Sounds like a good time. Nice times too.
Old 04-20-2015, 06:34 PM
NAPA 68 NAPA 68 is offline
Ken,
Did that driveshaft accomplish everything you wanted it to? Also, what bore diameter master cylinder did you settle with?
Thanks!
Tim
Old 04-20-2015, 06:37 PM
kwhizz's Avatar
Originally Posted by NAPA 68 View Post
Ken,
Thanks!
Tim
Yep......Driveshaft resolved all the issues.........Smooth as silk......Power Master 1" bore.......
