Old 02-12-2015, 12:43 PM
ironworks's Avatar
Looks good Bob. Nice to have another guy around here from Bakersfield.
Old 02-12-2015, 01:18 PM
BMR Sales's Avatar
Welcome Bob - very nice Fab work!
Old 02-12-2015, 04:33 PM
Che70velle's Avatar
Welcome to LatG Bob. Nice job on the car, and I can really appreciate the fact that you've held on to this project all these years, through much adversity. Hang in there, and keep the pics coming!
Thanks Dad!!
Old 02-12-2015, 05:06 PM
rpm56's Avatar
rpm56 rpm56 is offline
Thanks for the kind words Che70velle. I did put it up for sale about 5 years ago. But thanks to some logical words and encouragement from my much wiser brother, it's nearing completion.
Continuing with the motor crossmember, I ended up adding a Shelby style lower control arm tie in bracket. The theory is it provides support to the front lower control arm mounting point.
I added an adjustable tie rod stud to correct bump steer which is standard for Mustangs, and mad worse when the car is lowered. The set up uses a shorter rod end in place of the stock longer outer tie rod. This requires a longer adjustable sleeve which is available, buy the cost is stupidly high. I made my own from 6061-T6, with left and right hand 11/16"-18 threads. I'm using the sleeve on the left as the first one I made, on the right, was a fail.
The stock wheel opening from Ford sucks if you want to run wider wheels and tires because there is a horizôntal lip about 1"+ that will rub the sidewall. The fronts were fairly easy to roll flush.
The rears were a bit more difficult in that the quarter panel and outer wheel house double up the material. The 2 ply steel limits how tight of a radius can be made without cutting the metal. This was one of the first mods I made to the car and I'm happy with the outcome. Whether or not it's factual, I've always envied the GM and Mopar guys who had much more room for tires.
I still need to wire the car, get some gauges, install glass and body panels.
Bob
Build Thread- http://1969stang.com/forum/index.php...bitch-is-back/
There are 2 kinds of people, those who own pickups and those who borrow them.
Old 02-12-2015, 07:11 PM
renegade6 renegade6 is offline
Nice work. I'm generally not a Ford fan but, I'll make an exception for a Mach I.
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 02-12-2015, 07:21 PM
rpm56's Avatar
Thanks for the compliment and exception renegade6. It's funny how car guys can be so brand loyal, I know I am. I don't own any Ford stock, but been a Blue blood from day one as my Dad was a Ford fanatic.
Bob
Old 02-12-2015, 07:41 PM
rpm56's Avatar
Thanks Ironworks, I thought your screen name sounded familiar. I discovered you guys around a year ago when you advertised for a job opening in Camera Ads.
Bob
