Old 05-05-2015, 01:26 PM
jwcarguy jwcarguy is offline
Banned
Default LS3 Polished Holley High Ram Manifold, 102mm Throttle Body, 42# Injectors Price drop!
Item Location (City/State):Las Vegas, NV
Price:100
Description:
I am posting this for a friend, please contact Jason direct
This is a LS3 Holley High Ram, that has been polished also have a 102mm throttle body if someone needs one, have fuel lines/ crossover , fittings
***Wtt Trade For Fast 102mm Need A Fast Intake (this will not fit with my MSD atomic fuel injection so I am looking for a fast for trade)
Sold!!Holley high Ram
-$100 102mm with Adjustable TPS for the perfect tip-in, Custom built CNC 4130 Chromoly throttle blade, for High Boost,
-$175 Set of (-8-) Fast Green top 42lbs Injectors at 43.5-psi or 49lbs at 60-psi
in Las Vegas, NV
call/ text Jason (702)327-9907
email [email protected]
Old 05-05-2015, 07:27 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I want this so bad and it's a great price but won't fit under my hood
Old 05-05-2015, 08:04 PM
Banned
Thanks John
Yes it is pretty, my buddy spent a good dollar having it all polished
He is upset that he can't use it now
Jeff
Old 05-06-2015, 02:01 PM
1transam 1transam is offline
Would the height be similar to a truck intake?
1967 Chevelle "Pay the Man"
https://lateral-g.net/forums/showthread.php4?t=45303
2012 ZL1 Camaro "Paper filter stock"
Old 05-06-2015, 03:38 PM
Banned
Here are the specs on it:
Base Plenum Top Mounting Flange Height – 8.42” to the lifter valley cover flange on engine block.
Total Height with 92/102mm EFI Plenum Top – 12.32” to the lifter valley cover flange on engine block.
Port Size – 2.49” Height x 1.21” Wide
Mounting Flange Gasket Type – Standard LS3 Molded O-Ring
Plenum Top Gasket Type – 3/32” Round O-ring Cord
Throttle Body Flange Location, with 92/102mm EFI Plenum Top : Height – 8.42” (from engine block lifter valley cover flange), Longitudinal Location – 3.84” (forward from engine block front flange), Angle – 25 deg. (down from vertical)
Runner Length – 6.50”, As-Cast Runner Cross-Sectional Area – Tapered 4.25 in² to 2.77
Old 05-07-2015, 08:41 AM
Banned
price drop!
