Old 08-01-2015, 10:12 AM
paulk68 paulk68 is offline
Default Coil spring pocket Mod
Hi, I am getting ready to cut the coil spring pockets per the RIDETECH instructions to give my new coilovers complete shock travel. Is it ok to cut all the way to the end like pictured below. Just want to make sure before I cut haha
Old 08-01-2015, 07:20 PM
Rod P's Avatar
Rod P Rod P is offline
yes its fine to cut the opening larger like that
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-01-2015, 07:40 PM
Rod P's Avatar
yes you want to cut that half moon out
I used a plasma to rough cut first and the trial fit
cut it as flush as possible ...to shallow and it will interfere with the cap and spring
cut it large so there will not be any interference
it will also look good from above with the opening enlarged ...here was mine on the final trial fit
Rod Prouty
Bangshift Stories
Old 08-02-2015, 04:21 AM
Thank you ROD!!!!
