Old 08-05-2015, 02:26 PM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
Default Vaporworxs Tank
I have a Rick's Vaporworx with the 5th gen Camaro GM fuel pump w/internal pressure reg:I am trying to calibrate my Dakota Digital fuel gauge...does anyone know the ohms on the sending unit that Ricks uses?
Nobody at Ricks could give me a "for sure" answer.
Thanks!
Old 08-05-2015, 03:16 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
I'm not sure this is what you're asking, but the range of sender that's part of the Gen 5 in-tank pump is 33-240 ohms.
Old 08-05-2015, 05:24 PM
DKz Garage's Avatar
Thanks. I edited my post. I am looking for the ohms on the sending unit
Old 08-05-2015, 08:03 PM
Mkelcy's Avatar
Which I provided.
Old 08-06-2015, 05:35 AM
130fe 130fe is offline
Post
yeah, depends. Are you using the 5th gen fuel sensor (part of the fuel pump assembly) or one mounted separately? I know Carl C posted some info on how to integrate the 5th gen sender. My vaporworx tank uses one of the separately mounted 0/90 tube senders. Mike is correct about the 5th gen sender specs.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
Old 08-06-2015, 06:28 AM
DKz Garage's Avatar
Which I provided.
Thanks Mike....
How can you tell which sending unit you have?....I put the tank in and it's hard to see above the tank at this point. It seemed to me the sending unit was separate from the fuel pump...I suppose I could try the two different ohm settings on the Dakota digital and see which one works?? 0-90 and then 33-240. I know there is only about a gallon of fuel in the tank at this point.
Old 08-06-2015, 04:25 PM
CarlC CarlC is offline
Can you please post a photo of the top of the tank?
http:www.vaporworx.com
Old 08-07-2015, 04:01 AM
Post
My tank looks like this one-
http://s1134.photobucket.com/user/67...2c4c6.jpg.html
The sender is seperate from the fuel bucket assembly (has black and white wires).
Chris
1968 Camaro SS
LS3/T56
Old 08-07-2015, 12:48 PM
Musclerodz's Avatar
They don't use the sender internal to the pump, they use a seperate sender, should be 0-90 ohm
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-07-2015, 12:57 PM
DKz Garage's Avatar
I tried several of the preset senders in my Dakota Digital menu, including the 0-90ohm...with a know half tank of gas, it read as full?? I tried the "VDO" setting and it seems fairly accurate.... Not sure what to think other than this must be the correct choice.
Thanks for the input!
