Old 09-01-2015, 04:34 PM
Mac&Otto Mac&Otto is offline
If you are planning to build your cage to pass tech, check the rules first.
1.750 .120 wall tubing is usually the norm in a rule book. Using ChroMo will be pointless as it will not offer a weight savings.
Thank you sir.
Old 07-23-2016, 01:41 PM
Default Back At It!!!
I'm pretty sure I will make this the longest build ever!!! But, I've managed to get some time in on the car and it always gives you a momentum boost when you see progress. I've spent many hours fine tuning the Ultimate Products fiberglass just so I can bolt pieces down and open and close doors!!! It's not terrible but it's been fairly labor intensive getting things to fit. Never the less, I've made progress and hope to push on.
Old 07-23-2016, 01:43 PM
Body lines aren't bad!!!
Old 07-23-2016, 01:44 PM
Hood looks like it will fit with some massaging as well.
Old 07-23-2016, 04:46 PM
glassman's Avatar
glassman glassman is offline
Nice to see you back at it!!! Looking good!!
Mike
Old 07-24-2016, 06:06 PM
Thank you sir!!!!
Old 07-24-2016, 06:09 PM
x2 glad to know you're still making progress slow or not. I really dig this build. Good luck with it!
Old 07-25-2016, 10:03 AM
Thanks. I hate to make a plan on when I'll be ready for paint but hopefully I will keep plugging away and have it painted before October. We will see.
Thanks again, Cal
Old 11-24-2016, 11:09 AM
Sandro's 1969 502 Camaro's Avatar
Sandro's 1969 502 Camaro Sandro's 1969 502 Camaro is offline
Default Raised floor panels.
Hi, im in the process of raising my floor pans, for exhaust clearance. Just wondering if you used 20 gauge or 18 gauge metal?
Thanks, Sandro
Old 11-25-2016, 01:04 PM
Thanks, Sandro
I used both. It has some 18 gauge bracing and flanging but the actual beaded pan is 20 gauge. Plenty solid.
Cal
