Old 04-16-2015, 01:58 PM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default Entropy Radiators now available from MCB!
We have just agreed to sign up with Entropy as the demand for their product has been high and the reviews on quality/fitment have been great. We have done a lot of research on the product and we are confident these units will do a great job at a great price too!
We have some special pricing to offer you as well! Most Kits with Dual Fans are under $800!!
They make Rad's for MANY applications such as:
AMC, Buick, Chevy, Ford, Jeep, Mopar, and Pontiac!
They will also build customs.
LIFETIME WARRANTY!!!
Standard units use 1" tube and there is an option to upgrade to 1.25" tubes.
All units are fully welded, no epoxy.
LSX swap units are one of the most popular today. They offer both early and late style units (driver or pass side upper ports) and include the correct Steam Vent Port.
They come in a natural aluminum finish, but can be polished or powder coated.
They include an aluminum shroud and Dual fans as well.
Billet Filler neck and Stainless hardware
We strongly recommend their Fan controller which allows you to adjust the temp the fans come on at (160-215 Deg), allows you to run them at half speed start for a more gentle draw on your alternator, has an AC command input, and will work with your LS - PCM fan trigger or as a complete stand alone system as well!
Please Call, PM or Email with your application for a quote.
MCB
First Gen F-Body unit:
Polished Billet Caps:
LSX series Fan Control Module with wiring harness:
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 05-15-2015, 08:31 AM
Ketzer's Avatar
Ketzer Ketzer is offline
PM sent. About time to upgrade my cooling.
Jeff-
Old 05-15-2015, 11:31 AM
MCB Matt's Avatar
Jeff-
PM replied.
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 07-17-2015, 04:03 PM
Moose Moose is offline
hopefully someone that has one, or knows better then me will chime in. Going to order one. But, I've done away with all the wiring from the ls harness that i Wasn't using.. (the fan stuff)
Is there a controller that I can buy and wire in some how for on and off for temps? I have no idea what wire it is, and I'd have to pay tuner to set up.. etc...
Old 07-17-2015, 11:33 PM
MCB Matt's Avatar
The controller offered by Entropy will run the fans 100% independent of the LS or any computer. It can be triggered by its own sensor and programmed for on/off temps and can start the fans at half speed so the alternator doesn't take such a hard hit every time they spin up. It also has an AC input trigger you can run from a Trinary switch or any trigger you choose. It can be mounted in the car or under the hood, the wire length included is quite long.
They use 10GA wire and dual 40A fuses too.
OE non corrosive sensor. A bung for it can be installed at no extra cost or you can run it in the head.
160-215 turn on range
Take a look at it in entropys site under harness kits
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 07-18-2015, 04:05 PM
Matt
thanks Matt.. I'll get back with you in a few weeks after vacation to get it ordered.
Old 07-20-2015, 11:09 AM
MCB Matt's Avatar
Ok, sounds good. Enjoy your vacay!
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
Old 11-13-2015, 07:04 PM
Dipped's Avatar
Dipped Dipped is offline
Those look awesome! And the price is more than reasonable. Are they manufactured stateside?
Thanks.
1968 Firebird
lS3/T56/9"/24 Pistons/Forgeline VX1s/Faulty "Ride Height Too Low" Shocks
Old 11-14-2015, 06:18 PM
ProTouring442's Avatar
I've had an Entropy in my daily driver Jeep for about a year now. Works great. I would highly recommend them.
You ever wonder what medieval cook looked at the guts of a pig and thought, "I bet if you washed out that poop tube, you could stuff it with meat and eat it."
Old 11-15-2015, 06:02 PM
MCB Matt's Avatar
Thanks.
Yes, they are made here in the US.
Let me know if you need a price, we are also now offering PRC radiator packages as well.
Matt
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
