Old 11-14-2015, 07:42 AM
So many little touches on this car that will make it look great. I'm glad you're showing them since I don't know Mustangs well enough to pick them out on my own.
Old 12-11-2015, 08:05 AM
GPR's Avatar
GPR GPR is offline
Fixing the trunk gap
The owner wanted a spoiler but did not like how tall it was so we lowered the Mustangs to Fear spoiler and end caps about 1". It will be straight with the top of the quarter
Spoiler cut and test fitting
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 12-11-2015, 04:32 PM
crestronwizard crestronwizard is offline
Looking good , Rusty.
Old 12-29-2015, 02:25 PM
GPR's Avatar
GPR GPR is offline
The end caps were bolted, bonded and fiberglass mat added to the quarter panel
The spoiler was bonded to the deck lid and fiberglass mat added
Rusty Gillis
Port Richey Fl
Old 01-25-2016, 10:12 AM
GPR's Avatar
GPR GPR is offline
I epoxy primed the body
Block sanded and a little more bodywork
One coat of SPI epoxy primer
Two coats of SPI Turbo primer
Rusty Gillis
Port Richey Fl
Old 04-16-2016, 03:08 PM
GPR's Avatar
GPR GPR is offline
We took the body off the rotisserie and mounted it on a cart so I could finish the taillight panel and rear valance. I block sanded one more time
Epoxy primed
We want to test fit everything before paint. Starting installing the Rod & Custom suspension
Back on the ground
Getting ready to install the 347 engine and TKO transmission. Those hoses got to go.
Engine and trans installed
Ididit steering column with a Billet Specialties wheel
A few more photos
Rusty Gillis
Port Richey Fl
Old 04-27-2016, 03:09 PM
GPR's Avatar
GPR GPR is offline
Brian has the sheetmetal lined up.
Test fitting the new Stang-Aholics front valance
The gas filler will have to be moved down a little because the cap hits the deck lid.
Rusty Gillis
Port Richey Fl
Old 04-27-2016, 11:37 PM
Kcrain Kcrain is offline
Could you cut a little half moon in the lip of the deck lid to go around the gas cap? Kind of like the cut outs over the tail lights?
Old 04-28-2016, 05:35 AM
GPR's Avatar
GPR GPR is offline
That is what Brian said but I want to see if we can lower the filler neck first.
Rusty Gillis
Port Richey Fl
Old 04-28-2016, 06:38 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Looking good!
