Old 04-15-2015, 03:00 PM
GPR's Avatar
GPR GPR is offline
Default 1966 Mustang Coupe Restomod
This is what we are starting with. There is not a lot of rust but since Ford did not prime a lot of the inner structure we will be removing all the sheetmetal do any needed rust repair and epoxy priming. The plans are to install Rod & Custom front and rear suspension, Wilwood brakes, Currie 9", AOD and a 347. The body mods will be fender flares, drip rails removed, cowl vents filled in and maybe a few other things as we go.
One of the first things we did after bracing the body was to remove the cowl
The quarter panels were removed
The roof was also removed and there was only surface rust but in a few years it will get worse if it is not cleaned up now
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 04-16-2015, 06:21 AM
GPR's Avatar
GPR GPR is offline
I'm sure a lot of you are wondering why do we remove all the sheetmetal. The quarters were replaced at one time and we did not trust the workmanship and once they were removed we found rust in the outer wheelhouse. The roof was removed because Mustangs are known to rust in the inner structure in the front by the top of the A pillar. In this case we were lucky and only had surface rust but over time would became holes. The other area on coupes is the sail panel inner structure and we did find rust. A little rust on the left side but the right side had a few small rust holes starting.
Rusty Gillis
Port Richey Fl
Old 04-16-2015, 04:42 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Will be following.
Keep us posted.
Old 04-17-2015, 07:56 AM
Justin@EntropyRad Justin@EntropyRad is offline
Default Gutted much?
That's a lot of cut and paste work, but I bet will be killer when done
Old 04-17-2015, 02:59 PM
GPR's Avatar
GPR GPR is offline
New firewall and cowl was sanded and epoxy primed
The cowl side panels and A pillars needed to be replaced
Test fitting
Rusty Gillis
Port Richey Fl
Old 05-03-2015, 08:30 AM
GPR's Avatar
GPR GPR is offline
Ready for epoxy primer
Two coats of SPI black epoxy primer
Rusty Gillis
Port Richey Fl
Old 05-03-2015, 08:54 AM
GPR's Avatar
GPR GPR is offline
Lower cowl welded in place
The welds were ground down and epoxy was brushed on
Upper cowl fit and welded
Fender apron to cowl extensions welded in place and started to test fit the roof after it was sanded and the back side epoxy primed
Rusty Gillis
Port Richey Fl
Old 05-03-2015, 09:45 AM
DBasher's Avatar
DBasher DBasher is offline
Looks great Rusty, thanks for the step by step pictures!
Whose sheet metal do you use for all the replacement panels?
Old 05-04-2015, 05:36 AM
GPR's Avatar
GPR GPR is offline
I'm a dealer for Dynacorn.
Rusty Gillis
Port Richey Fl
Old 05-29-2015, 08:08 AM
GPR's Avatar
GPR GPR is offline
Brian has done a lot of work since I last posted
The rear frame rails had a little rust and needed to be replaced
Test fitting the trunk floor and gas tank
Plug welding the trunk drop offs
Fitting the rear package tray and sail panels
The quarter panels were shaped wrong and had to be modified
Fitting the taillight panel and end caps
Left outer wheelhouse welded in place
The right side was to long and had to be modified
Starting to weld the sail panels
Rear panel welded in place along with the sail panels
Rusty Gillis
Port Richey Fl
