Old 02-03-2016, 11:04 AM
fishface's Avatar
fishface fishface is offline
Default Fuel rail connecter
Hi, getting some ideas on the best connector for my ls3 fuel rail. I will be using ptfe flexible hose and have rotated the fuel rail to put the cońnection on the passenger side. Will I need a 90 degree connector here as the bend in the hose would be extreme if running parallel with the fuel rail?? Any help appreciated.
Old 02-03-2016, 01:36 PM
Che70velle's Avatar
You'd have to bring the fuel line up behind the engine, in order to need a 90 degree fitting. I flipped my fuel rail, as you are, and I ran my fuel line along the frame, onto the inner fender (strapped of course), and right into the fuel rail.
This is a straight fitting with -6 PTFE hose.
Thanks Dad!!
Old 02-03-2016, 02:47 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I ran mine pass side the behind engine ito 90* fitting at fuel rail.
IMHO cleaner then flipping the fuel rail.
Old 02-03-2016, 06:38 PM
Che70velle's Avatar
That looks great Vegas! My objective was to keep the fuel line away from heat sources as much as possible. Your way does look cleaner though.
Thanks Dad!!
Old 02-03-2016, 07:37 PM
fishface's Avatar
Thanks for the responses and pics guys!! I can see what I am going to do.
Old 02-03-2016, 07:56 PM
randy randy is offline
do as vegas did or get a billet fuel rail.
Old 02-04-2016, 12:49 PM
Jimmy Sean's Avatar
Jimmy Sean Jimmy Sean is offline
I uses one of these. https://www.techafx.com/catalog/50
1969 Firebird, L-76 LS2, T56, Speed Tech Torque Arm, Build Thread
Instagram @jimmysean69
Old 02-05-2016, 05:44 PM
Efi69Cam Efi69Cam is offline
Originally Posted by Jimmy Sean View Post
That looks like a great option. I take it you get an AN fitting from them for the other end?
Old 02-05-2016, 06:15 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
I also flipped my fuel rail on my LS3 to the passenger side. I ran a 90* swivel hose end into a Russel fuel rail fitting. I recommend the fuel rail fitting with the lock nut rather than the plastic clip.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 02-05-2016, 06:24 PM
Vega$69's Avatar
or Like I did on my new car with Holley Fuel Rails.
Ran fuel line on driver side and remote battery cable on pass side
Name:  IMG_0719 (2) (640x480).jpg
