Old 11-16-2016, 01:27 PM
paulk68 paulk68 is offline
Default removing paint from hood
So I purchased a used gm cowl hood for my 68 camaro and I want to strip the paint as much as I can before having the nooks and cranies blasted. should i use a chemical paint stripper to get a good chunk off or should I use a 3m wheel on my power drill? or should i use something else? let me know
Thank you
Old 11-16-2016, 01:46 PM
DT69Cam DT69Cam is offline
You have several options here Paul.
1-DA it with 80 grit
2-Chemically strip
3-Have it media blasted
I have had pretty good results just with the DA.
69 Camaro Convertible (LS3/TKO in the works)
Old 11-16-2016, 02:07 PM
2-Chemically strip
Perfect thank you, I looked for the magical stamping today after applying some chemical stipper to the rear corner. NOTHING. still happy it is a gm hood and at 300 bucks I could not be happier to have it for my project!!!
Old 11-16-2016, 05:11 PM
dhutton dhutton is offline
Make sure you properly neutralize that stripper or you will have paint issues down the road. I recommend a DA to remove paint on a hood.
Old 11-16-2016, 05:18 PM
Been doing a a fair amount of thus for the last few weekends. I have used aircraft stripper and a citrus stripper ... the aircraft is faster but very nasty... the citrus you can get at Home Depot.. have to let it sit 13 hrs or do but it's the way to go.
Then use a DA with 80 or 36
Old 11-16-2016, 11:51 PM
232_ray 232_ray is offline
Default " Magical stampings " ??
Any chance u can explain this magical stamping and or post pics of where I'm supposed to look for this stamping it's the first time I've heard of this stamping. Thanks I appreciate the help. I'm restoring my car and any new/old info would help to learn.
I looked for the magical stamping today after applying some chemical stipper to the rear corner. NOTHING. [/QUOTE]
Old 11-17-2016, 03:12 AM
[/QUOTE]
I kinda joke about it being a "magical stamp". After some research I found that cowl hoods that were on cars from the assembly plant had a date code stamped in the rear driver side corner. It would be a number 1-52. Hoods made by GM for the after market did not get these stamps. Here is a picture of the area of where it should be
Old 11-17-2016, 09:24 AM
Default Magical stamp
Awesome thanks sir. I really appreciate it. I'm currently restoring what I think is a 69 Z/28 and trying to cover everything to be able to authenticate it and to prove to the nay sayers. Thanks again
I kinda joke about it being a "magical stamp". After some research I found that cowl hoods that were on cars from the assembly plant had a date code stamped in the rear driver side corner. It would be a number 1-52. Hoods made by GM for the after market did not get these stamps. Here is a picture of the area of where it should be[/QUOTE]
