Old 11-11-2016, 07:43 AM
paulk68 paulk68 is offline
Default t-56 magnum shifter removal
So this may be a very dumb question but is removing the stock shifter on a t-56 magnum as easy as unbolting the 6 bolts? Is there anything I should watch out for when removing? should I put it in neutral or anything like that?
Old 11-11-2016, 07:58 AM
will69camaro will69camaro is online now
That's it, it's pretty simple. I put it in neutral and pull to the side to break the seal.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
Old 11-11-2016, 09:46 AM
Thank you!!!
Old 11-22-2016, 06:20 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
The only thing I would add is that there is a plastic bushing in the shift rod that the shifter fits into that came out when I removed my T56 Magnum shifter. Just be sure it is in place when the shifter is reinstalled. I also seem to remember some one selling a brass replacement T56 shift bushing that seems like a good upgrade.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
