Old 01-13-2015, 09:31 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Originally Posted by cwylie View Post
Hey I noticed the hood latch clears the heat exhanger but hits the top lip on the a/c condenser. How did you all resolve this? Does cutting the lip off the condenser give you enough clearance? Should I worry about messing up the condenser if I cut that lip off?
I think it says in the directions,, that you go like seven holes in on each side notch it out. I did that and then the latch still hit when you went to pop the safety on the latch. So you can do two things. Either trim the latch down where it will hit the condenser. Buy a vw style latch and catch for the hood and build a plate or order one from ironworks I believe sells one. The only other choice would be hood pins. I am not big on them but it may be a simple solution. I think some grinding on the back of hood latch will take care of it.
Old 09-10-2015, 12:13 AM
Bmf5150 Bmf5150 is offline
Anyone have dimension of this heat exchanger??
Old 09-10-2015, 03:47 AM
rocketrod rocketrod is offline
http://www.summitracing.com/parts/ci...t/model/camaro
Straight from the link above, but I think the got the height and width dimensions crossed.
Width (in): 26.000 in.
Height (in): 36.000 in.
Rod
1969 Camaro - LS2/4L70E
Old 09-10-2015, 10:17 AM
Thanks for posting
Old 09-11-2015, 11:35 AM
Do they make a fan assembly that fits this heat exchanger ??
Old 09-14-2015, 06:44 PM
Where it's mounted it draws through the radiator so that fan pulls the air for it.
Old 06-06-2017, 05:22 PM
You guys happy with yours so far?
Old 06-24-2017, 09:06 PM
I'm not up and running yet but Travis is doing well with his.
Old 06-25-2017, 06:46 AM
I know MattG, who started this thread, had was happy with it before I bought his entire setup. I haven't installed it yet, but I heard nothing but rave reviews for C&R products.
Rod
Old 12-16-2017, 08:58 AM
bullittcustoms bullittcustoms is offline
I got this piece in this week from Summit. It only came with the Heat Exchanger and top bracket. Is there a bottom bracket and mounting hardware? Am I missing pieces? (It's typical if I am) There is nowhere to mount the bottom pegs....
TIA - Derek
