Old 06-06-2017, 05:22 PM
Bmf5150 Bmf5150 is offline
You guys happy with yours so far?
Old 06-24-2017, 09:06 PM
I'm not up and running yet but Travis is doing well with his.
Old 06-25-2017, 06:46 AM
rocketrod rocketrod is offline
I know MattG, who started this thread, had was happy with it before I bought his entire setup. I haven't installed it yet, but I heard nothing but rave reviews for C&R products.
Rod
1969 Camaro - LS2/4L70E
Old 12-16-2017, 08:58 AM
bullittcustoms bullittcustoms is offline
I got this piece in this week from Summit. It only came with the Heat Exchanger and top bracket. Is there a bottom bracket and mounting hardware? Am I missing pieces? (It's typical if I am) There is nowhere to mount the bottom pegs....
TIA - Derek
Old 12-16-2017, 11:36 AM
jimmythehand jimmythehand is offline
Mine is for a 68 but i think they should be the same. there should be a bottom bracket and some mounting hardware as well. here ia link to a pic showing the bottom bracket.
http://www.lsxmag.com/features/sema-...or-69-camaros/
the mounting hardware that came with mine included three bolts/nuts/and spacers. i could not figure out how to incorporate the spacers, so installed without just fine. I called C&R and discussed the spacers and did not come to a final conclusion, although they were very friendly and receptive.
Old 12-16-2017, 01:22 PM
That's exactly what I thought!! Thanks for the info!!!
Derek
Old 12-17-2017, 12:29 AM
I used the spacers to go inside the lower radiator support so it wouldn't crush when you tighten the bolts.
Old 12-19-2017, 10:27 AM
l2azorback l2azorback is offline
C&R now makes a heat exchanger for the Gen V LT4 application in a first gen with inlet and discharge on the driver's side (as opposed to the LSA application on passenger side). Same price too!
Regards,
Larry
