Old 03-09-2018, 06:58 AM
DWC's Avatar
DWC DWC is offline
I got the subframe, front suspension, and brakes installed. I used the Detroit Speed body mounts- very nice pieces.
The upper link tabs were installed. I never figured out an accurate method to measure how straight the axle was before/after the welding. So, in an effort to reverse the warping from mounting the tabs on the top of the axle tube, I welded roughly the same amount of beads on the bottom of the axle, then ground it off. Not very accurate or scientific, but it will hopefully function until I upgrade the rear end.
Finally got it all together and installed.
Once I install the rear brakes, I can get the car on wheels and install the subframe connectors.
Daniel
Old 03-09-2018, 07:01 AM
DWC's Avatar
DWC DWC is offline
The progress in the above posts' took place over the past 5 or 6 months and is up to date with how the car sits now.
Daniel
Old 03-09-2018, 07:05 AM
JON Q's Avatar
JON Q JON Q is offline
Daniel, if you posting pictures, there are no pics on any of your posts
Old 03-09-2018, 07:11 AM
DWC's Avatar
DWC DWC is offline
Well, yes, I thought I was posting photos. I can see them on my end. Let me work on that.
Thanks for the heads up.
Daniel
*Edit- photos are hopefully working now.
Old 03-09-2018, 09:50 AM
shelteredV's Avatar
shelteredV shelteredV is offline
Cool
pictures are there for me. Looks really good! This is pretty much what I'm on scale with, but I don't weld so I'm dependant on my buddy to weld for me when he has time. It's good to see a garage build to keep us regular guys motivated and not feel too overwhelmed
Don't get me wrong- the big pro builds are totally inspirational and beyond awesome.
Old 03-09-2018, 11:43 AM
dmc69's Avatar
dmc69 dmc69 is offline
Nice Work! Always good to see a nice garage build!
DMC69- 69 SS350-LS3/6speed
Old 03-09-2018, 12:56 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Very nice work so far,keep updates coming
Old 03-09-2018, 01:02 PM
JON Q's Avatar
Daniel
Maybe they were still loading at the time I posted since the time is pretty close to your posting. I see them now. Nice work.
Old 03-10-2018, 04:37 AM
DWC's Avatar
DWC DWC is offline
Thanks guys, I appreciate the kind words.
Daniel
Old 03-19-2018, 05:45 PM
DWC's Avatar
DWC DWC is offline
The rear rotors and calipers are installed.
Got the car down on all four wheels. Measured and confirmed front subframe to body alignment- all looked good and square.
Cut holes in the driver and passenger floor pans and welded the subframe connectors in. I primed the welds but still need to seam seal them.
Daniel
