Old 12-21-2018, 04:34 PM
jarhead's Avatar
jarhead jarhead is offline
allot of work you've got done! Really like the mods and the car chosen to do them on!
joe
Semper Fi
My 68 Torino
Old 12-24-2018, 10:44 PM
hackster's Avatar
hackster hackster is offline
Originally Posted by CMillwheels View Post
That’s great news Sean, keep it going! If you need an extra set of hands, or just a helper, with the cage and exhaust let me know. Happy to help.
Chris
Thanks Man, Its so unimpressive compared to your Camaro
Car looks great and Love the seats
and let's not forget the Dash
Thanks dude, I am hoping that all those pieces turn out well, going to start on the back seat and door panels hopefully next week.
Dash turned out sick came back from Powder Coat on Friday.
Originally Posted by Boosted Falcon View Post
Great build and looking forward to seeing the finished product.
Thanks dude, me too =)
Thanks, car isn't too impressive looking but should be pretty fun when its done.
Managed to make a little progress on the car but managed to screw up a $150.00 chunk of tube in the process as well.
Seriously had a ton of parts ready to go and have made so little progress. I needed to track down some **** for the holiday on Saturday, then get it back home, then get the bender finally bolted down in the middle of the shop, move the jeep cause I couldnt swing the damn tube around.
Frustrated around that but managed to be 1.75" wider than it should have been. Second time fit like a champ.
Gutted again.
Bending **** up again.
****ed up tube
The real one in place, needs some trimming to get it to fit and a bunch more toob as well
Steering arms need to go in for zinc coating so they both match.
Exhaust parts and pieces.
Out of town for the holiday but hope to make some progress next weekend.
Merry Christmas to all of my friends on the internets!!!!
Sean
Old 12-25-2018, 09:13 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Did those exhaust hangers come from Vibrant also?
Jeff-
Old 12-28-2018, 09:57 AM
hackster's Avatar
Jeff-
Hangers are Stainless Works ordered from Summit
Been messing with some tubing and struggling with what to do. Halfway tempted to just bag on this idea after getting 742 different opinions on the roll bar/roll cage/street car/harnesses/track car debate. All good info, just getting analysis paralysis.
Main hoop is done for the most part. Just tacked in place for now but it came together pretty nicely.
Floor plate and rear fender well plates are built and ready to go in for the drivers side.
Going to keep trucking on this over the weekend and see what I can come up with.
Its a street car that will do some track days.
Might even be able to work on the exhaust this weekend if I get my **** together.
Sean
Old 12-28-2018, 11:15 AM
DBasher's Avatar
DBasher DBasher is offline
Sorry about the “help” but you did ask, lol.
Just stick to the plan of a point to tie your harnesesses to and move on. If and when you decide to build a track specific car you can bust out the bender again and go full retard.
Old 12-28-2018, 11:34 AM
SSLance's Avatar
SSLance SSLance is offline
I'm happy with my very well built 4 point bar in my street car. The four attachment points are directly above body the frame mounts and have significant plates between tubes and floor. The down bars have no bends in them.
Anything more than that is overkill and even detrimental for most street cars.
Lance
Old 12-30-2018, 09:45 PM
hackster's Avatar
All good my friend, I always appreciate the help and ideas.
I read through your entire build thread after you posted this and its the one thing that sold me on redoing my rear design to above the rear suspension instead of on top of the wheel wells.
Thanks for taking the time to read my post and provide some great advice!!!
In the end, stiffness and function won out over form and fitment of the rear seats.
I can tell you that this was a **** ton of work.
It went in and out of the car too many times to count 90 % of them by myself. I had a hand today thank god.
checking the main hoop for fitment against the seats
Mock up of the rear plates and down tubes.
Main structure tacked together and mocked up the down bars, ready to pull it all out and start welding
Commencing final welding. Was not quite sure how the 1/8" plate would weld to the factory sheetmetal but once I had the welder dialed in it was good to go.
Pretty happy with the way these laid out, directly over the rear crossmember and shock mount should stiffen up the back of the car a lot.
The way I built it I was able to slide the final welded main hoop with the down bars tacked on forward so I was able to final weld up the top of the down bars nicely and 100%.
Worked like a charm
I had a slight kick angle on one of the legs and it needed to get pushed back a hair so a little push with the porta power and it was all good!!
Welded out
The **** show of fire paper and all kinds of crap.
Hope to be able to get it scuffed, primed and painted tomorrow, maybe start on the exhaust next weekend.
Thanks for the pointers all.
The Following User Says Thank You to hackster For This Useful Post:
Nonhog (12-30-2018)
  #148
Old 12-30-2018, 10:21 PM
I like your decision. You are someone who enjoys the big track - vs big parking lots - so the more bars the better IMO.
Old 12-31-2018, 09:14 AM
SSLance's Avatar
I like it! That is going to work out very nicely for your needs. Nice execution...
What size tube is that, it looks big? I believe Charley used 1.75" 0.120 wall on mine but can't remember for sure. He said it was good for any sanctions up to actual wheel to wheel racing (no door bars). He was able to tilt mine forward to completely weld on top of the bars then tilt it back into place. Looks like you had to scoot forward instead because of the sheet metal the rear down bars go thru.
Lance
Old 12-31-2018, 07:31 PM
hackster's Avatar
So true, cannot wait to see what this bitch will do on the track.
Thanks man, and I agree it should work just fine.
Same as yours 1.75" .120 DOM tubing but this car is pretty small so the tubing looks big. There is a joke in here somewhere but too inappropriate for anything on a forum =)
Sometimes you get some great pointers. Tying the main hoop into the b pillars would stiffen up the chassis significantly. So I whipped these puppies up today.
Turned out pretty good considering it was a little bit of an after thought. Ties into the factory seatbelt mount on the b pillar.
Went and got some paint matched to the seats...its close, not perfect. 2 coats of etching primer and 2 coats of color going on. Regret the cage being so close to the headliner at this point it was a bitch to mask and I got some on the headliner. Hope that I can use some mineral spirits to get it off.
Turned into the worlds fattest contortionist the past few days, was the most fun when I was painting and painted myself a few times.
Hope to get the rear wheelwells buttoned up in the next few weeks so I can get the carpet in, then seats. Exhaust after that.
Appreciate the good feedback on the b pillar tie in.
Sean
