Old 08-13-2019, 08:57 AM
redfire69's Avatar
Thanks guys, do you think it's OK to go right off the master with 9/16 and 5/8 connectors on 3/16 line, i.e. is it OK to run 3/16 directly into this MC?
Ron
69 Camaro Redfire
Old 08-13-2019, 09:40 AM
572Camaro's Avatar
Yes, absolutely
That is exactly what I did using a stainless tube nut for 3/16" line with a larger thread to fit the master cylinder directly.
No adapters required!
I bent my own lines, flared the ends, and installed the master cylinder with no leaks at the reservoir.
By the way, Classic Tube Company should have the wider tube nut you are looking for. I would not purchase the tube nut from their major competitor because when I did, it was junk and all galled at the seat. I threw it in the trash.
If you want pics, just let me know and I'll send you some,
I just wanna help
Jim Gloe
Old 08-14-2019, 05:22 AM
redfire69's Avatar
Thumbs up
Jim, this is the exact info I was looking for, I was looking to use 3/16 lines directly with the larger tub nuts but was not sure it would work w this MC. Thanks so much!!! Ron
Originally Posted by 572Camaro View Post
Yes, absolutely
I just wanna help
Jim Gloe
Ron
69 Camaro Redfire
The Following User Says Thank You to redfire69 For This Useful Post:
572Camaro (08-14-2019)
  #14
Old 08-15-2019, 01:44 PM
572Camaro's Avatar
Hey Ron,
Sometimes it's tough to trust a stranger when it comes to BRAKES.
I just came back from the shop with four pics to give you a visual so you can gain faith in what I have shared.
Here goes..,
And yes Ron, my ego required I send you a pic of the red car I took pics of, which happens to be on the COVER and month of December for the Sherwin Williams 2019 Calendar.
jim gloe
(572 Camaro)
The Following User Says Thank You to 572Camaro For This Useful Post:
redfire69 (12-10-2020)
  #15
Old 08-16-2019, 06:55 AM
redfire69's Avatar
Hey Jim,
Thanks again, that's awesome. I'm also building a big block, great minds must think alike! What headers are you running?
Ron
Ron
69 Camaro Redfire
Old 08-17-2019, 09:56 AM
572Camaro's Avatar
Hey Ron,
Great minds DO think alike.
I absolutely love big blocks, but won’t say anymore about that here in case the LS boys are watching..,
1. Headers.., I fabbed my own using SPDexhaust.com tubing and flanges.
2. My 572 is a 10.2” deck height so header fitment was a pain.
3. So is access to plug #7
4. Since I am fuel injected, with O2 sensors, NO header leakage is allowed (or it would influence my air/fuel ratio while in “closed loop”. So I worked with Randon at Percy’s High Performance to construct really nice header gaskets!
You and I can now purchase them at Summit Racing..,
part number = PHP-66089. My first set cost me $400. But You can purchase them now for $34.99.
5. Please keep me posted. Do you have any more pics of your project?
jim gloe
Old 08-17-2019, 10:04 AM
572Camaro's Avatar
ps: love the Chevy intake, the really clean look, and the black small hex wide flange ARPs securing the intake.
Are you going carb or fuel injection?
Old 08-19-2019, 01:22 PM
redfire69's Avatar
Very cool, thanks again for info on the headers and gaskets. Plan is carb for now. I have a build thread below, finally making some good progress.
https://lateral-g.net/forums/showthr...=15120&page=15
Best, Ron
Ron
69 Camaro Redfire
572Camaro (08-20-2019)
  #19
Old 05-21-2020, 11:24 AM
67droptop 67droptop is offline
What power booster ?
