Most likely will, the LT E92 controls the alternator and has the ability to run it up to 15+ volt output or all the way down to like 12.5. I did a lt1/10 speed swap last summer and that alternator only charges the amount it needs. Many times on the test drives I noticed what appeared like like low output but Mitch at swaptime USA (harness supplier) said that is the tech built into the OE system. Also said that strategy was based on the OE battery type which is AGM. Using the truck water pump pump and balancer with a custom power steer pump mount I put together a simple effective drive, the pump has the alternator mount, A/c mount built in along with the belt tensioner works for your regular gm chassis
