Closed Thread
Old 08-08-2024, 06:05 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by OLDFLM View Post
Mark,
Are you keeping the stock steering wheel or going with your preferred MOMO?
I like the cruise control!
I like the look of the stock steering wheel for this project. Once I start driving it. I might swap it.
Stielow Engineering
camcojb (08-08-2024)
  #432
Old 08-08-2024, 06:08 PM
Stielow's Avatar
Originally Posted by HRS View Post
Here are 2 versions of blue wheels - All blue and the center blue. All blue might be too much blue being 18" wheels?
Thanks for the effort, the photo shop job looks good. Still on the fence on black or blue wheels.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
camcojb (08-08-2024), colorado80439 (08-09-2024)
  #433
Old 08-08-2024, 09:47 PM
camcojb camcojb is online now
If you do go with the blue, I like the black outer/smaller blue version. Makes it look a lot more like a period correct 15" wheel/tire.
srode1 (08-09-2024)
  #434
Old 08-09-2024, 09:23 AM
srode1 srode1 is offline
Yep, my vote would be Blue with the black outer lip too. Probably flatten the black a tad to come closer to your tire color.
  #435
Old 08-09-2024, 06:46 PM
TechNova TechNova is offline
Mark, what is the driver's sport mirror from? Is it non-remote?
I plan to put a pair on my son's car but the driver's I have has the manual remote cables. I do not want to cut the original doors panels.
  #436
Old 08-11-2024, 02:56 PM
jason jason is offline
Hey mark , question regarding your transmission. Do you run the .63 6th gear , or the .50 6th gear model
  #437
Old 08-12-2024, 09:16 AM
Stielow's Avatar
I use G-Body sport mirrors. They are remote operated from the factory. They have a cable on them stock. I make new mechanical parts for them to make them manual adjustable.
I have tried a few different ways of doing it. This is not easy. I knew someone would eventually ask the question so here are a few photos. To get it to fit in the housing is a lot of trial and error.
Stielow Engineering
The Following 3 Users Say Thank You to Stielow For This Useful Post:
camcojb (08-12-2024), dhutton (08-12-2024), NAPA 68 (08-12-2024)
  #438
Old 08-12-2024, 09:20 AM
Stielow's Avatar
I have been using the .63 because it is more fun for road tours when you are in the mountains.
If you live in KS and you want better fuel economy get the 0.5. The engine rpm drops a lot but makes the 4-5-6 gear spacing large.
With the big gear rpm drops the engine is lugging or spinning up. It is a personal preference deal.
Stielow Engineering
camcojb (08-12-2024), NAPA 68 (08-12-2024)
  #439
Old 08-12-2024, 10:28 AM
jeff71 jeff71 is offline
Mark, did you go with the close ratio and have D&D do the .50 swap on this build?
The Following User Says Thank You to jeff71 For This Useful Post:
  #440
Old 08-12-2024, 01:01 PM
Stielow's Avatar
D&D can give you the tight ratio 1-5 and add a 0.5 6th. This works great with a blower motor with a ton of torque because it can pull the 3.25 rear gear and the OD. For this build with a stock LS7 I closely copied the 2014 Z/28 with a tight 1-6 and a 3.73 rear gear. It will turn a little bit more RPM at 80 but should drive great.
Stielow Engineering
Closed Thread
