Old 11-21-2024, 03:14 PM
andrewb70's Avatar
The 8HP90 that I picked up had a mystery converter in it. It didn't look stock and frankly I didn't trust it. So I called up Circle D and had a discussion about my requirements. Here is what they suggested:
This is their hybrid 8HP90 converter. Externally it is the same size as the 8HP70 converter, which is 1/2" smaller in diameter than a stock 90 converter, but internally it is built to work with the 8HP90 transmission.
Here you can also see the Domiworks bellhousing adapter.
and the Domiworks converter adapter.
Andrew
Instagram @dr__efi
I deliver what EFI promises.
My YouTube Channel
The Following 9 Users Say Thank You to andrewb70 For This Useful Post:
214Chevy (11-21-2024), 68454RS (11-22-2024), camcojb (11-22-2024), dhutton (11-21-2024), kwhizz (11-30-2024), syborg tt (12-07-2024), waynieZ (12-05-2024), will69camaro (11-22-2024), WSSix (11-21-2024)
  #212
Old 11-29-2024, 07:23 PM
andrewb70's Avatar
I had a little care package delivered today. Here are the fuel rail brackets, printed in stainless steel.
Tomorrow I will drill and tap as needed and maybe run the sides over some emery cloth on a granite block.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 5 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (11-29-2024), kwhizz (11-30-2024), waynieZ (12-05-2024), will69camaro (11-29-2024), WSSix (11-29-2024)
  #213
Old 12-02-2024, 06:13 AM
andrewb70's Avatar
I used a bench-top drill press and a step drill to open up the holes on the front and on the bottom.
Here they are mounted to the intake and holding up the fuel rails.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 3 Users Say Thank You to andrewb70 For This Useful Post:
syborg tt (12-07-2024), will69camaro (12-02-2024), WSSix (12-02-2024)
  #214
Old 12-02-2024, 07:46 AM
camcojb camcojb is online now
andrewb70 (12-02-2024)
  #215
Old 12-02-2024, 06:42 PM
That's really cool. Little things like that will be neat to point out to people at car shows etc.
The Following 2 Users Say Thank You to WSSix For This Useful Post:
camcojb (12-03-2024), syborg tt (12-07-2024)
  #216
Old 12-03-2024, 07:38 PM
andrewb70's Avatar
Most people won't even notice.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following User Says Thank You to andrewb70 For This Useful Post:
  #217
Old 12-06-2024, 07:47 PM
andrewb70's Avatar
Here is the final raw, 3D printed aluminum charge pipe:
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 4 Users Say Thank You to andrewb70 For This Useful Post:
camcojb (12-06-2024), dhutton (12-07-2024), syborg tt (12-07-2024), WSSix (12-08-2024)
  #218
Old 12-07-2024, 02:37 PM
andrewb70's Avatar
I ran across some videos by Devin Vanderhoof. It seems that he too has discovered the Hardwire Electronics PDM products. In fact, he has become the biggest distributor in the US for Hardwire. As you may recall, I already have a PDM 25 under the dash, but after seeing the videos for the new PDM 28, I knew that's what I needed in the GTO. I will use the PDM 25 in the Cougar or the Suburban.
Here is the PDM 28 as it arrived.
The size of the PDM 28 is substantial. Here you can see it compared to the Holley Dominator ECU. They are roughly the same size.
The reason for choosing the new PDM 28 is that it has two CAN busses. With the release of the Holly CAN documentation, the PDM 28 is fully compatible with Holley EFI.
Holley had a 3D model of the Dominator available for download.
An email to Hardwire provided the 3D model of the PDM 28.
I once again used my Shining 3D Einstar 3D scanner and generated a scan of the GTO dash and glove box area.
https://youtube.com/shorts/mhHSHdmFs..._UB9Yk2dgtfszA
The plan is to design a mounting system for the Dominator and the PDM in the area that used to be occupied by the glove box.
Andrew
Instagram @dr__efi
My YouTube Channel
camcojb (12-07-2024), fleetus macmullitz (12-08-2024), syborg tt (12-07-2024)
  #219
Old 12-07-2024, 03:39 PM
syborg tt's Avatar
This has to be one of my favorite builds on this site
marty-mj
  #220
Old 12-07-2024, 07:35 PM
andrewb70's Avatar
Thanks for the kind words Marty.
If anyone is in the process of wiring their car, please post questions about the Hardwire PDM 28. This thing will basically handle all of the vehicle functions, although I made a conscious decision to leave the fuse panel and the bulkhead connector in place. However, the only thing that it will handle is the front and rear lighting. All other systems are getting moved to the PDM.
With the Holley Dominator and TurboLamik communicating over CAN, and now the PDM also on the CAN bus, some really trick things are going to be possible.
Andrew
Instagram @dr__efi
My YouTube Channel
The Following 2 Users Say Thank You to andrewb70 For This Useful Post:
fleetus macmullitz (12-08-2024), syborg tt (12-08-2024)
