Old 12-13-2025, 06:17 PM
jarhead's Avatar
jarhead jarhead is offline
John, I always enjoy seeing your work
Merry Christmas to you and your family too!
joe
Semper Fi
My 68 Torino
The Following 2 Users Say Thank You to jarhead For This Useful Post:
camcojb (12-13-2025), Goosesdad (12-19-2025)
  #782
Old 01-01-2026, 06:13 PM
Goosesdad's Avatar
Thanks guys!!!
Took a couple weeks off visiting family for the holidays, left the spoiler in the mold to fully cure and help keep it's shape.
Here is the part out of the mold and just starting to smooth all of the seams where the gelcoat seeps into the joints of the mold.
First test fit under way.
Have a great day!
John
My Build Thread:
The Following 5 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (01-01-2026), dhutton (01-01-2026), fleetus macmullitz (01-02-2026), Tinker (01-03-2026), WSSix (01-08-2026)
  #783
Old 01-02-2026, 01:03 AM
groovyjay's Avatar
groovyjay groovyjay is offline
It just keeps getting better and better!
The Following 2 Users Say Thank You to groovyjay For This Useful Post:
camcojb (01-02-2026), Goosesdad (01-03-2026)
  #784
Old 01-03-2026, 04:19 PM
Goosesdad's Avatar
Thanks!
The fiberglass nose, purchased about 6 years ago, shrunk up a bit, so I'll cut it and reshape to get the shape back. Glass does move if you don't anchor it and this piece has been off the car for some time now. My bad, definitely not the manufactures fault. Fix started today.
Have a great day!
John
My Build Thread:
The Following 2 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (01-04-2026), syborg tt (01-06-2026)
  #785
Old 01-04-2026, 09:57 AM
Still seems to fit better than many I've seen.
Old 01-04-2026, 03:54 PM
zz430droptop67rs's Avatar
zz430droptop67rs zz430droptop67rs is offline
John, I was just wondering if you're going to use a front license plate?
It would be shame to cover up that work.
The Following User Says Thank You to zz430droptop67rs For This Useful Post:
  #787
Old 01-06-2026, 10:50 AM
Goosesdad's Avatar
Agreed. It's from Custom Works and it fit very well. A bit of massaging and it will be perfect and I always liked what Keith did revising the shape.
I had planned on using the stock grill insert but the re-pop wasn't great and there was a guy at SEMA who hand made a metal insert with larger grids. It was extremely well executed and looked great. I'm going to redesign the factory grid pattern and try to 3D print a revised version. Down the path now, we'll see if I can get it close enough to fit into this nose piece and then fit the fiberglass to it.
Thanks! Yep, for sure no front plate. Not required in Idaho, though I probably should have a plan for a temp setup while driving in other states.
Have a great day!
John
My Build Thread:
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
camcojb (01-06-2026), syborg tt (01-06-2026), zz430droptop67rs (01-06-2026)
  #788
Old 01-07-2026, 04:08 PM
Goosesdad's Avatar
Here's the first attempt at doing a plastic insert. Stretched my Solidworks skills big time. Had some help, thankfully. Just hit send for the first test print.
Have a great day!
John
My Build Thread:
camcojb (01-07-2026), syborg tt (01-10-2026), WSSix (01-08-2026)
  #789
Old 01-15-2026, 10:11 PM
Goosesdad's Avatar
Good progress on the grill. My printer isn't large enough to print in one piece but still in mock-up, will find someone to print each side in one piece...hopefully.
Still in the works but pleased so far.
First one out of the mold, glass cut for the second.
In the mold, little chilly right now in ID so helping the cure with some heat.
Initial trim and a quicky sand. lots more to do.
Have a great day!
John
My Build Thread:
camcojb (01-16-2026), syborg tt (01-15-2026)
  #790
Old 01-15-2026, 10:12 PM
syborg tt's Avatar
Very nice
marty-mj
camcojb (01-16-2026), Goosesdad (01-16-2026)
