Old 05-23-2008, 06:23 PM
well, it's not looking good for Power Tour, as this damned car is fighting and screaming till the very end. As soon as I solve one issue two more crop up. I think I'll run out of time.
Right now, no speedo and related, no trans shifting. VSS issue I'd guess, but not sure how to solve it yet. Then as it was idling all of a sudden both pipes started smoking a lot. My guess, oil from the turbo drains backing up or just too much oil period. I have a ported pump on this thing and about 45 psi at idle, maybe it's just too much. The drain lines are 5/8" i.d. and are kink-free downhill to the pan. It's run this long before and never done this, but of course it starts now. I have the proper oil restrictor fittings Precision supplied with the turbos, so I dunno...........
Haven't driven it more than 200 ft without some major issue cropping up like my valve covers melting.............. which of course caused a massive oil leak that drenched everything. Not the fault of the covers, I'm going to run the same ones on another LS build, just not on a turbo car with the headers right next to the covers. Everybody with them on normal motors have not had any issues, great pieces.
So as you see, I've got several big things to sort out, and honestly I'm burnt out on this car. It will get sorted, but I really set my goal of one month for teething pains; one week may not be enough.
