  #26
Old 09-22-2005, 09:09 PM
Musclerodz's Avatar
Originally Posted by 68protouring454
that makes no sense.
most normal 3 stage paints, have a ground coat, which usually is alot light and full of pearl/metallic. then the mid coat is a darker shade of main color (lets say red) and very translucent (does not cover well) and it takes 3-5 coats to darken the ground coat or till you reach the color you want or are trying to match, dodge did a bunch of 3 stage colors on there cars etc in the early 2000's, a real **** up, heres some i just did last week, and there is no way you could get same color from ground coat with no mid, or by mixing same color in 2 stage, no way.
this is a pic of the 3 stage i just did i repair to, on a 2001 dodge mini van, color is inferno red.
first pic is mid coat(2nd coat) 2nd pic is color of mid coat, 3rd pic is ground coat can,4th pic is ground coat, which is first coat
see how in mid coat pic, it is very translucent on top where you can see right thru it then on bottom it is dark as there is more down there, then over on ground coat you can see how much pearl/metallic is it, thats the whole deal to 3 stage is you can spray the mid coat till you get desired darkness or effect if doing an overall, and it will look entirely different if you put one coat of mid coat or 4 coats of mid coat.
I don't disagree as I had hell with the first HOK Kandy job I did. Look up W9510K. What my Dupont paint store told me was the only difference between this particular bc/cc and tri-coat formula was the mid-coat and had very little magenta in it creating a candy. I may have mis heard and the mix ratios were slightly different, but I am fairly sure I heard him right say the the only difference was the mid coat. I will call tommorrow and clarify. Here is the bc/cc formula in chroma base. It has lots of pigment.
W9510K "Milano Red"
864 magenta 53.4g
867 red 78.9g
850 brilliant red 101.2g
150k binder 217.6g
Mike
Mike Redpath
Musclerodz & Customz
facebook page
