Old 10-04-2005, 06:49 AM
uneasyrider's Avatar
uneasyrider uneasyrider is offline
Default Hi
Seen the site and thought I'd join. Looks like something along the lines of what I'm doing, guys that like American Muscle that will take a corner. Here's a picture of my 1974 TA, it's got a long way to go still but the major stuff is done that makes it run. The car has been around me since 1983 when my buddy Chris bought it from the second owner. Chris owned it for about a year and then he sold it to a guy that owned it for about a year and then my buddy Kevin bought it. He drove it for about two weeks and we spun a rod bearing in it and there it sat from 1986 until now. It has 97k original miles on it. It was originally ordered without the bird from what I can tell but I had to add it. Everone wanted me to put it on so I gave in to popular consent and I'm glad I did. Everyone expects the bird to be there and likes it. At some point before he got it the engine had been swapped from the stock 400 to the '70 RAIII block it currently has. One of the owners had also put a gold bird and decals on the car I assume to be like "Smokey and the Bandit". It was originally a 400 4-spd car with a posi and no accessories. I've had the car to 156mph and it was still pulling so I'm guessing that it can go over 160mph and the calculated top speed is 170mph. I don't think I will be doing that again without 4w disc brakes, lowering the car a bit and putting new suspension bushings on it. Everything is still as is and the bushings are a bit dry. I have new shocks and brakes but the brakes are original. I will list the current spec's below.
E-heads (out of the box)
462cid (400 block 0.060 over)
Eagle crank and H-beam rods
10.2:1 compression
Pistons = SRP
RPM manifold
Crower part # 60243 Grind # 284HDP: (2,500-6,000)
@ 0.050 228/235
112deg lobe sep.
0.479/0.494 (w/1.5:1)
1.5:1 rockers
stock 800cfm Q-jet
Hooker Super Comp. headers (2" primary, 3.5" collector)
Kumho ECSTA MX 255/45 17's front and 285/40 17's rear "Y" speed rated 186 mph
Stock Super T-10 4-spd
Comp Engineering Subframe connectors
Comp Engineering Traction bars (to be installed soon)
10 bolt GM, 2.73 rear (soon to have a new Eaton posi)
A TA isn't a TA if it can't take a corner.
