Old 04-14-2009, 04:10 PM
Fluid Power's Avatar
Default Stiff clutch pedal question
So I bleed the brakes and the clutch and holy leg work out Batman! The clutch is so stiff the car would be dangerous to drive. I am running a Tilton master cylinder and throwout bearing and the stock Camaro pedal setup. The pedal ratio is way out of whack given the mounting position of the MC and the stock pedals. (mental note to check ratio during initial mock up) So far, it seems my only option is to move and mount the master cylinder up higher, which given the firewall, (not smoothed) runs into some really crappy looks. I would then have to remotely mount the reservoir. This will change the pedal ratio which will decrease the pedal feel. Maybe I cannot see the forest for the trees, am I missing any other options????
Darren
