Old 12-08-2010, 12:25 PM
Look at that weight transfer.....
It would be great if this was drag racing and I had the travel available. Since the Optima Challenge, I know the driver and car need help to get where I want to be. My first obstacle is that I've found that my rear shocks are bottoming out big time. I don't know if removing the rear sway bar made it that much worse or I've just been to dense to notice. I did know the RR was but the LR always had a little left until recently.
I decided to start from scratch and design a new bracket to increase my shock travel by 5/8". Any more and I will run into rear differential cover to crooss member contact or tunnel to pinion housing contact. The brackets are being cut now. Number two is the spring rate is clearly to soft. So I started from scratch and did a base spring rate calculation. To do that, you loosen the spring adjuster collar until the spring is at full length with just a hint of tension. You take that measurment and then drop the car on the ground to see how far the spring is compressed.
Free length is 11.75"
Compressed is 8.25"
11.75-8.25=3.5"
Current Spring Rate is 175=152 Adjusted due to 20 degree angle
3.5 x 152=532
Desired bump travel 2.58
532/2.58=206 Spring rate needed
So basically I need about 50 lb/in more than I currently have to control the weight. I'm going to start with a 220 lb/in spring and go from there. The ideal compressed spring length is around 9.34. That is over an inch more than I have now!!! I'm positive that my shocks were bottoming out under acceleration and some cornering. I'm hoping the extra spring rate and 5/8 extra shock travel keep the rear from bottoming out.
Up next may be the front springs. I have a feeling they are a little soft as well. I really want to keep the ride nice so I need to walk a fine line. I really want to get the car where it stays flatter in all the events. To much body roll and weight transfer is not good for what I do with the car. Stay tuned..
