Go Back   Lateral-g Forums > Classifieds > Wanted/WTB
Old 10-18-2011, 01:56 PM
nickcornilsen's Avatar
nickcornilsen nickcornilsen is offline
Default Wanted: c5, c6 6spd Torque tube, dead or alive
Hi
I'm looking for a torque tube assembly. I dont' care if the rubber couplers are shreaded, or if the aluminum tube is broken, OR if the driveshaft itself is no good.
All I need is the bellhousing that bolts to the transmission, the end that bolts to the bellhousing on the engine, the bearings within, the shaft that engages the clutch, the shaft that slides over the transmission input shaft, the coupler flanges that attached to the mentioned shafts. I'll be making a, custom length driveshaft that doesn't go inside the tube.
As for shipping, if you cut the middle of the tube out, so all I had were the two ends (which contain the parts I talked about earlier in this thread) it could be shipped UPS easily.
I figure someone's got to have a bad torque tube laying around?
