Old 01-29-2012, 08:08 PM
fultz1275's Avatar
fultz1275 fultz1275 is offline
Default Throw out Bearing question
what would cause, what I assume is the throw out bearing, to feel like it is spinning when the tranny is in neutral. when I push in the clutch pedal in, it goes away. I have a tremec 5 speed with mechanical linkage. It has just started doing it after a put a 1/2" spacer under the trans mount to give it the correct pininon/driveshaft angle. The "feel" of the clutch pedeal is different too. When stopping quickly and pushing on the clutch pedel, it is very hard to push in. Would raising the tranny by 1/2" affect the linkage and ultimately the throw out bearings ability to engage/disengage?
