Old 07-27-2012, 09:20 AM
makoshark makoshark is offline
The VHX gauge set has the optional BIM add-on modules. They add to the original cost of the VHX gauges, but can be added at later times. The VHX set has dual digital displays, so allow for more things to be displayed as well as 2 trip meters. You can set one trip meter for oil changes to remind you when to change your oil. It has a 0-60 timer, 1/4 mile eta and mph as well as RPM recall and MPH recall. The cluster is wired with a single CAT5 cable coming from a seperate box where all the main wiring is done allowing you to remotely mount the box removing a bulk of wiring from behind the dash. They give you digital display of all readings as well as analog. They have warning lights and you can install a shift light. You can also setup different warnings especially if you add any of the BIM modules. One of the BIM modules that I purchased allows you to add 4 more temperature readings. I'll add one for the trans and oil temp. I'll also add a rearend temp later to it. You can also add another module to give you a compass reading as well as a temperature reading inside the car or outside. There are several more BIM modules that do different functions. It can also display what gear your in for automatic trans cars. They are awesome gauges, I am just not overly smitten with the display appearance options.
