Old 09-20-2012, 08:50 PM
gerno's Avatar
gerno gerno is offline
Default Metal chunks in oil pan - help please
Changing my oil tonight to prep for a track day tomorrow I was lucky enough to find a nice surprise on the magnet. Pics are below.
Can anyone help me figure it out before I pull the engine and tear it down? Engine is a SBC 377 with 400 4 bolt block, forged eagle crank with 400 mains, 6" Scat rods, JE flatops, 195cc Trick flow heads with springs to handle up to 600" lift. It has roller rockers and stud girdles. Cam is a Comp solid with net lift ~530" and lifters with the oil holes in them (forget what they are called). Timing chain is a double roller without a cam button.
I'm thinking it has to be teeth from the disti gear or cam gear but I pulled the dist and it looks ok. I looked down the disti hole at the cam and tapped the motor over. I don't see any teeth that look damaged.
Name:  Chunks in oil 1.jpg
Name:  Chunks in oil 2.jpg
