Old 06-09-2013, 12:35 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Originally Posted by Ron Sutton View Post
Erik,
If you don't mind sharing about your car ... how much HP? How do you drive the car? How much does it weigh? How big are the tires?
Don't mind sharing at all, car is still being built, I'm setting the record for longest build time. It's a 69 Camaro, mild LS2 at best so most ever probably 500hp, 18" 275 tires, possible mini-tub someday. I would do the C-Clip eliminators in a heartbeat but the last I checked it couldn't be done with the C6 Z06 brakes and Kore3 adapters I'm using. I'm assuming though that those brakes are beefy enough that unless under a real hard corner they should keep the wheel somewhat in place until I can get stopped. If there's a better option out there now I would love to hear about it.
Erik
69 Camaro
