Old 03-24-2014, 12:01 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Thanks guys.
This weekend felt good. Its always good when the car becomes driveable again!
Originally Posted by 72Z/28 View Post
Chad I know it is frustrating that the the progress is very slow, however at least you are figuring out the problems and sorting them out accordingly. I am on the same boat as you are.
I remember you had an issue with your alignment and the front wheels were sitting too close towards the back of the fender. I am having the sMe problem so just wondering if you have sorted out this issue with caster adjustment and was the caster that ended up with?
Are you running the TCI setup with wider than 245 front tires? I believe they have since updated their design to eliminate the problem I had. I'm currently running my old 245 front tires and the setup up works perfectly with 5* of caster. Its the mixing of 5*+ and a 275 front tire that I started having problems. A solution for which has been back burnered until now.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
