Old 04-05-2014, 08:43 PM
gerno's Avatar
gerno gerno is offline
I like the look of that panel Steve.
Thanks. They are simple but look much better than the log ones. They are also flat so there is room to add some lower bars on the roll bar I have as well.
I continued not he rear seat closeout today. I decided to grab some 1/2 sq tube and build up a structure to lay the ABS on. The whole structure will be bolt in in cans I need to access something. I'm pretty happy with the results so far. I wish the metal supply house was open today because buying steel at Home Depot is such a rip off For now the ABS will be flat panels using 1/4" cap screws with washers to add a little flare. If I decide to do the side exhaust the panels will stay flat. If I decide to exit the exhaust out the back I'm thinking the battery can go in the rear section and I can build out 2 storage compartments in the front.
