Old 03-20-2015, 08:34 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by Build-It-Break-it View Post
Have you came up with a price yet for just the adapters And seal?
Not yet, I am machining a few sets next week and once machine time is determined,,,, I can put a cost to them. I do however expect the pricing to be similar as the "weld-on" kits I sell since they are very similar, and as you may or may not know those are $900.00 a set.
Additionally, the basic kit for this "bolt-on" setup will include the axle seal and ARP hardware. Appreciate your interest! Thanks!!
Originally Posted by Rod P View Post
HOLY CRAP! thats awesome....totally want
Thanks Rod, I am VERY proud of this set-up! Would love to see you beating on a set of these soon! Let me know
Originally Posted by efs69 View Post
Stay tuned for newly machined sets
Originally Posted by 130fe View Post
Stupid question- does this make a conventional rear with torino ends into a semi-floater? Curious on pricing as well. Any info would be appreciated.
I do not think any questions are stupid and believe that is how we all learn. To answer your question, a conventional rear with "torino ends" IS considered a semi-floater. This set-up would fall closer into the full floater category.
In a nutshell, with a semi-float axle, the axle shaft both carries the weight of the vehicle and transmits torque which directly relates to the failure of bearings, seals, and ultimately piston knockback.
With a full-float axle, the weight of vehicle is supported by the axle housing-more specifically and in this situation, the C6/7 Hub/Bearing that is attached/bolted to the end of the axle tube. Torque is now transmitted by the axle shaft that carries literally no weight since the Hub/Bearing Unit supports the vehicles weight now...
