LSA Accelerator Pedal Assembly
Quick question regarding the correct accelerator pedal to use on my LSA/70 Camaro build. A little background: I have a complete BP automotive wiring harness for my LSA swap (thanks Tom!). The harness was originally set up for a LSA + 4l60e trans, I have decided to run a T-56 manual trans. So I know I need to have the wiring converted for the manual trans, which is no big deal. Doing some research, GM had two different Accelerator pedals for the 2009 CTS-V (manual vs Auto)...not sure what the difference would be?? I've read that a C6 Corvette pedal would work??
Looking for input on what pedal will be compatible with my harness...and be the cleanest install in a 2nd gen Camaro??
As long as I am looking for input....Has anyone run into issues with the Crank Pulley on an LSA engine having clearance issues with a DSE sub-frame (2nd gen Camaro)??
Thanks in advance....
Reason: add text
