  #29
Old 04-10-2022, 12:45 PM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Thanks guys for kind words.
Time to hang the quarters.
All is build so that the new repro stock width will fit. Now days all is about wide body.
Should I do that..?
No, I'll "massage" just a little, for the rear tubs. 1/2" wider from the middle. Just used kick shrinker to shrink pie cuts to the top flance. Tricky to get them done and then copy to other side.
First thing is to sand them clean and paint inside with same 2-k epoxy as everything else. Left strip at the edge without paint. Will paint after welding and hammering. Also installed some sound deadening. Got carried away abit. Nobody will ever see, but had to do it..
Tig welded all around. Exept the wheel arches. Those I glued with 2-k body adhesive. Really strong stuff. Area of finger tip (1cm2/ 0.15sq in) will hold 200kg (440lbs). Glue is closed cell stuff. will not absorb moisture. Also fitted quarter extensions witch I made years ago in Per the Metalman Sweden's shapping class with Ben, father of the Mechhammer.
Need to finish the seams, slapper, shrinking disc, hammer and dolly to get everything straight and smooth.
Next is time to modified the front fender wheel arches and I already have started to with rear end, full floater.. again some thing different.. When some careful calculations and I can order my wheels..
, Juhani
The Following 3 Users Say Thank You to SuperB70 For This Useful Post:
jarhead (04-12-2022), Mikael A (04-10-2022), syborg tt (05-18-2022)
