Old 01-25-2013, 05:56 PM
Kenny Kenny is offline
That isn't half and half but I can see that working great except in cold weather.
That isn't actually what we used, but I saw it and thought it would be more along the lines of a streeter.
You just have to trust that the thinner unheated oil works better in cold temps than trying to heat thicker oil..... I promise. There would be nothing wrong with a pan heater though.
Originally Posted by preston View Post
Were you cooling the high pressure oil coming out of the pump or after it came out of the engine on its way back to the tank ?
Is there a preference ? Does it make a difference ?
I run a oil/water cooler on the pressure side before it goes into the engine. I like this because as you mentioned it also warms up the oil which is good for a street based car, but I was thinking of adding additional cooling capacity via an air to air. But packaging means I would like to put it on the low pressure side. Thoughts ?
It really didn't matter as long as we passed sufficient volume to avoid starving the suction side. It really doesn not take long to heat a 0 or 10w oil. I guess if you are cruising in sub zero temps..... We also found power with a particular brand of dino oil over every synthetic we tested. It was the "fake" synthetic, if you will, the "superclean" crude that many companies pass off as synthetic.
By the way..... you guys do know they make a thermostatically controlled bypass, right?
