Old 03-07-2007, 03:33 PM
wheelermojo wheelermojo is offline
Default Offset Shifter for 5speed in 67 camaro?
I recently bought a Tremec tko 600 from a friend of mine and have run down almost all the parts necessary to put it in a 67 camaro. I'm having some difficulty finding a solution for the shifter and drive shaft. I'm trying hard to avoid cutting my trans tunnel because the car has all the original floor/trunk pans in it and is a matching #'s car. I've called several companies and found out that Pro 5.0 is coming out with an offset shifter in 6-8 weeks but I'm hoping to put the trans in before then. I wanting to see if anyone had an answer or has already been through and solved this problem. Also I'm having trouble finding a drive shaft for sale that will fit - all the companies that I've called only sell the kit for GM's. If anyone knows the correct length for the drive shaft or where that I might be able to purchase one that would be a huge help. Thanks again for any responces - I'm eager to get the car ready for warm weather.
