Old 08-02-2007, 01:24 PM
Marcus SC&C's Avatar
The package was originally designed to be bolt in only but ChassisWorks services a more hardcore performance/drag racing crowd than AirRide as a rule. They`d like to see it welded in addition to the bolts to take a belt and suspenders approach and add some additional strength. Not a bad idea at all. Bolt in only should be fine for cruising and general street use but if you`ve got 750hp and a 6 speed by all means weld it in too. Mark SC&C
Old 08-02-2007, 06:13 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I guess the part I'm really confused about is mixing it with the mini Tub. the mini tub notches out a part of the frame. Is this anywhere close to where the G bar is mounted?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 08-03-2007, 05:41 AM
rich-allen's Avatar
rich-allen rich-allen is offline
The DSE offset shackles moves the rear of the leafs toward the gas tank about 1-1/2" and they use the same under body mount in the front.
The G-bar also uses the original front mount however, the G-bar is only 1" in dia. The leafs are 3" or so inches wide. In theory, you should gain more clearance using the G-bar than the offset shackles.
Hope this helps.
Rich
67 RS/SS
